How to: Use from PHP |
PHP users use the RMCLink COM Component interface. Specifics on using this component from PHP are described below, including a complete example script. The example script is also included as a PHP project in the RMCLink example projects.
As is common for all languages, the first step is to create an instance of the RMCLink class. This is a two step process: first create an RMCLinkServer object, and then use that object to create the appropriate type of RMCLink object.
To create the RMCLinkServer object, use the following line in your PHP file:
$srv = new COM("RMCLink.RMCLinkServer");
You can now use the newly created srv variable to create the RMCLink object using one of RMCLinkServer's CreateEthernetLink, CreateSerialLink or CreateUSBLink methods. The following line creates a link for communicating with an RMC70 at IP address 192.168.0.22:
$rmc = $srv->CreateEthernetLink(2, "192.168.0.22");
Notice that as described below, PHP cannot use enumerations, and therefore, although the CreateEthernetLink, CreateSerialLink and CreateUSBLink methods take a DeviceType parameter, the literal value for the desired enumeration must be used.
PHP cannot use enumerations. Therefore, although the CreateEthernetLink, CreateSerialLink and CreateUSBLink methods are specified to have the devType parameter be of type DeviceType, you must enter the literal value of the enumeration member you want to use. Similarly, for the IsConnected method's ping parameter, you will have to use the literal values in place of the PingType enumeration members. Each enumeration topic lists the literal values next to the named values (e.g. ptDoNotPing = 0).
To read data from the controller, use the ReadFFile or ReadLFile methods. It is not necessary to use the ReadFFile_Script or ReadLFile_Script methods.
$data = $rmc->ReadFFile(8,8,2);
Notice that the ReadBit and ReadBitField methods can be used as well.
Use the WriteFFile and WriteLFile methods. They need to be passed a PHP array with the same length as the count parameter. Refer to these method's topics for an example.
The following code is an example of a PHP program. This example script is also included as a PHP project in the RMCLink example projects.
PHP (Sample.php) |
<?php
// NOTE: PHP does not support enumerations, so we use the literal value (dtRMC70=2).
$rmc->Connect();
echo("Actual Postion = {$data[0]}, Actual Velocity = {$data[1]}");
$rmc->Disconnect();
RMCLink COM Component | How Do I Overview | RMCLink Component
