RMCLink COM Component RMCLink.WriteFFile Method |
Writes to one or more floating-point (F) registers in the controller. Notice that since all RMC100 registers are integers, WriteLFile should be used instead for that controller type. Use WriteFFile when writing to floating-point RMC70, RMC150, or RMC200 registers. Compare with WriteLFile.
Sub WriteFFile ( _ file As Long, _ element As Long, _ count As Long, _ data As Variant _ ) |
Dim instance As RMCLink Dim file As Long Dim element As Long Dim count As Long Dim data As Variant
instance.WriteFFile(file, element, count, data) |
File number of the first register to write to. See the RMCLink Register Reference for details.
Element number of the first register to write to. See the RMCLink Register Reference for details.
count
The number of registers to write.
data
The data to write to the controller. The following data types are supported:
A single value of Single or Double data type (not an array)
Single-dimensional array of Single or Double data type elements
Two-dimensional array of 1xN or Nx1 Single or Double data type elements
Notice that all RMC100 registers are integers. Therefore, using this method to write data to the RMC100 will simply round the values to integers before writing them to the controller.
Error Code |
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
One of the file, element, count, or data parameters are out of range. |
rmcEDisconnecting = 1002 |
rmcEBadType = 1003 |
Invalid type passed in for write data parameter. |
rmcEBadLength = 1004 |
Array length of write data does not match count parameter. |
rmcEDisconnected = 1005 |
rmcESocketInternal = 1008 |
rmcECancelled = 1010 |
rmcETimeout = 1011 |
rmcESocketReadError = 1015 |
rmcESocketInvReadLen = 1016 |
rmcESocketWriteError = 1017 |
rmcESerialIOE = 1021 |
Serial IOE error. |
Serial framing error. |
rmcESerialBreak = 1023 |
Serial Break error. |
rmcESerialOverrun = 1024 |
Serial overrun. |
rmcESerialRxOverrun = 1025 |
Serial receive overrun. |
Serial parity error. |
rmcESerialTxFull = 1027 |
Serial transmitter full. |
rmcEConnectionBroken = 1028 |
rmcEPartialWrite = 1029 |
rmcEReadOnly = 1030 |
Attempt to write to read-only registers. |
rmcEBadAddress = 1032 |
Attempt to write beyond the end of a file. |
rmcEUSBInternal1 = 1051 |
rmcEUSBDisconnected = 1054 |
The following code example illustrates the use of the WriteFFile method.
' Issue a Move Absolute command to Axis 0 (registers F16:0-5).
Dim data(5) As Single
data(0) = 20 ' Move Absolute (20)
data(1) = 10.5 ' Requested Position (10.5 in)
data(2) = 12.5 ' Requested Speed (12.5 in/s)
data(3) = 100 ' Acceleration Rate (100 in/s/s)
data(4) = 100 ' Deceleration Rate (100 in/s/s)
data(5) = 0 ' Direction (0=nearest)
rmc.WriteFFile fn70CommandArea, 0, rmc70CmdRegsPerAxis, data
Dim srv, rmc
Dim data(5)
rmc.WriteFFile 16,0,6,data
// Issue a Move Absolute command to Axis 0 (registers F16:0-5).
var data = new Array(6);
data[0] = 20; // Move Absolute (20)
data[1] = 10.5; // Requested Position (10.5 in)
data[2] = 12.5; // Requested Speed (12.5 in/s)
data[3] = 100; // Acceleration Rate (100 in/s/s)
data[4] = 100; // Deceleration Rate (100 in/s/s)
data[5] = 0; // Direction (0=nearest)
rmc.WriteFFile(16,0,6,data);
RMCLink Class | RMCLink COM Component | WriteLFile
