RMCLink COM Component RMCLinkServer.CreateSerialLink Method |
Creates an RMCLink object for communicating with a controller (either RMC70 or RMC100) over a serial port.
Function CreateSerialLink ( _ devType As DeviceType, _ portName As String _ ) As RMCLink |
Dim instance As RMCLinkServer Dim devType As DeviceType Dim portName As String Dim returnValue As RMCLink
returnValue = instance.CreateSerialLink(devType, portName) |
devType
Specifies which type of RMC will be linked to. It must be either dtRMC70 or dtRMC100.
portName
Specifies the serial port to use for communicating with the device. Typical names include "COM1" and "COM2".
Returns a reference to a new RMCLink object created for communicating with the specified device type on the specified serial port.
Notice that this method does not in any way try to connect to the controller. This method simply creates the RMCLink object. To connect to the device, you will need to call the RMCLink.Connect instance method. This method will support any com port on the PC.
Because the object is only created and the connection is not made, this method returns immediately.
Error Code |
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
Invalid argument. Ensure that devType was either dtRMC70 or dtRMC100 and that portName had a serial port name. |
The following code example illustrates the use of the CreateSerialLink method.
Set rmc = srv.CreateSerialLink(dtRMC70, "COM1")
Dim data As Variant
Dim srv, rmc, data
Set rmc = srv.CreateSerialLink(2, "COM1")
var rmc = srv.CreateSerialLink(2, "COM1");
RMCLinkServer Class | RMCLink Class | RMCLink COM Component
