RMCLink COM Component RMCLink.WriteLFile Method |
Writes to one or more integer (L) registers in the controller. Since all RMC100 registers are integer registers, this function should be used for all writes to RMC100 controllers. It should also be used when writing integer values to RMC70, RMC150, or RMC200 registers. Compare with WriteFFile.
Sub WriteLFile ( _ file As Long, _ element As Long, _ count As Long, _ data As Variant _ ) |
Dim instance As RMCLink Dim file As Long Dim element As Long Dim count As Long Dim data As Variant
instance.WriteLFile(file, element, count, data) |
File number of the first register to write to. See the RMCLink Register Reference for details.
Element number of the first register to write to. See the RMCLink Register Reference for details.
count
The number of registers to write.
data
The data to write to the controller. The following data types are supported:
A single value of Long data type (not an array)
Single-dimensional array of Long data type elements
Two-dimensional array of 1xN or Nx1 Long data type elements
Error Code |
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
One of the file, element, count, or data parameters are out of range. |
rmcEDisconnecting = 1002 |
rmcEBadType = 1003 |
Invalid type passed in for write data parameter. |
rmcEBadLength = 1004 |
Array length of write data does not match count parameter. |
rmcEDisconnected = 1005 |
rmcESocketInternal = 1008 |
rmcECancelled = 1010 |
rmcETimeout = 1011 |
rmcESocketReadError = 1015 |
rmcESocketInvReadLen = 1016 |
rmcESocketWriteError = 1017 |
rmcESerialIOE = 1021 |
Serial IOE error. |
Serial framing error. |
rmcESerialBreak = 1023 |
Serial Break error. |
rmcESerialOverrun = 1024 |
Serial overrun. |
rmcESerialRxOverrun = 1025 |
Serial receive overrun. |
Serial parity error. |
rmcESerialTxFull = 1027 |
Serial transmitter full. |
rmcEConnectionBroken = 1028 |
rmcEPartialWrite = 1029 |
rmcEReadOnly = 1030 |
Attempt to write to read-only registers. |
rmcEBadAddress = 1032 |
Attempt to write beyond the end of a file. |
rmcEUSBInternal1 = 1051 |
rmcEUSBDisconnected = 1054 |
The following code example illustrates the use of the WriteLFile method.
Set rmc = srv.CreateEthernetLink(dtRMC100, "192.168.0.28")
' Issue a Go (G) command to Axis 0 (registers L8:0-5).
Dim data(5) As Long
data(0) = &H81 ' Mode (S-Curves, Accel/Decel Mode 1)
data(1) = 100 ' Acceleration Rate (100 in/s/s)
data(2) = 100 ' Deceleration Rate (100 in/s/s)
data(3) = 10000 ' Requested Speed (10 in/s)
data(4) = 4000 ' Requested Position (4 in)
data(5) = Asc("G") ' Go (G) command
rmc.WriteLFile fn100CommandAxis0, 0, rmc100CmdRegsPerAxis, data
Dim srv, rmc
' NOTE: VBScript does not support enumerations, so we use the literal value (dtRMC100=1).
Set rmc = srv.CreateEthernetLink(1, "192.168.0.28")
Dim data(5)
data(5) = ASC("G") ' Go (G) command
rmc.WriteLFile 8,0,6,data
// NOTE: JScript does not support enumerations, so we use the literal value (dtRMC100=1).
var rmc = srv.CreateEthernetLink(1, "192.168.0.28");
// Issue a Go (G) command to Axis 0 (registers L8:0-5).
var data = new Array(6);
data[0] = 0x0081; // Mode (S-Curves, Accel/Decel Mode 1)
data[1] = 100; // Acceleration Rate (100 in/s/s)
data[2] = 100; // Deceleration Rate (100 in/s/s)
data[3] = 10000; // Requested Speed (10 in/s)
data[4] = 4000; // Requested Position (4 in)
data[5] = 71; // Go (G) command
rmc.WriteLFile(8,0,6,data);
RMCLink Class | RMCLink COM Component | WriteFFile
