RMCLink COM Component RMCLink.ReadFFile_Script Method |
Reads one or more floating-point (F) registers from the controller. This method is only for use in VBScript or JScript. Use the ReadFFile method with other languages. ReadFFile_Script is typically used to read floating-point registers from the RMC70, RMC150, or RMC200.
Function ReadFFile_Script ( _ file As Long, _ element As Long, _ count As Long _ ) As Variant |
Dim instance As RMCLink Dim file As Long Dim element As Long Dim count As Long Dim returnValue As Variant
returnValue = instance.ReadFFile_Script(file, element, count) |
count
The number of registers to read.
This variant will be filled with the data read from the controller. The variant data type will be a single-dimension 0-based array of Variant elements, each which in turn holds a Single. The length is determined by count.
The only difference between ReadFFile_Script and ReadFFile is the format of the data returned in the Variant return value. For ReadFFile, the Variant holds a single-dimension 0-based array of Single elements. For ReadLFile_Script, the Variant holds a single-dimension 0-based array of Variant elements, and each Variant element in turn holds a Single. This extra layer of indirection is required by some scripting languages (VBScript and JScript, for example), but is otherwise less efficient and should be avoided when ReadLFile is supported by your language.
Notice that JScript arrays are not directly compatible with the arrays returned by ReadFFile_Script. Therefore, before using the array elements, you must call JScript's toArray method on the variable returned by ReadFFile_Script. See the JScript example below.
Notice that all RMC100 registers are integers. Therefore, using this method to read data from the RMC100 will simply convert the values to floating point. For example, reading a value of 25 will be stored as a Single in the output array as 25.0.
Error Code |
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
One of the file, element, or counts parameters are out of range. |
rmcEDisconnecting = 1002 |
rmcEDisconnected = 1005 |
rmcESocketInternal = 1008 |
rmcECancelled = 1010 |
rmcETimeout = 1011 |
rmcESocketReadError = 1015 |
rmcESocketInvReadLen = 1016 |
rmcESocketWriteError = 1017 |
rmcESerialIOE = 1021 |
Serial IOE error. |
Serial framing error. |
rmcESerialBreak = 1023 |
Serial Break error. |
rmcESerialOverrun = 1024 |
Serial overrun. |
rmcESerialRxOverrun = 1025 |
Serial receive overrun. |
Serial parity error. |
rmcESerialTxFull = 1027 |
Serial transmitter full. |
rmcEConnectionBroken = 1028 |
rmcEPartialWrite = 1029 |
rmcEBadAddress = 1032 |
rmcEUSBInternal1 = 1051 |
rmcEUSBDisconnected = 1054 |
The following code example illustrates the use of the ReadFFile_Script method.
Dim srv, rmc, data
RMCLink Class | RMCLink COM Component | ReadFFile | ReadLFile_Script
