PingType Enumeration |
The PingType constants are used to select whether the RMCLink.IsConnected method will try pinging the device before returning to verify that the link is still connected.
ptDoNotPing = 0 |
RMCLink.IsConnected should return immediately whether the link was connected as of the last communication attempt. |
ptPing = 1 |
RMCLink.IsConnected should first do a test communication with the device to make sure that the link is still connected. |
RMCLink COM Component | Enumeration Types | RMCLink.IsConnected
