RMCLink COM Component RMCLink.ReadBit Method |
Reads a single bit from an integer (L) register in the RMC. ReadBit is typically used to read the value of a status bit in the RMC.
Function ReadBit ( _ file As Long, _ element As Long, _ bit As Long _ ) As Boolean |
Dim instance As RMCLink Dim file As Long Dim element As Long Dim bit As Long Dim returnValue As Boolean
returnValue = instance.ReadBit(file, element, bit) |
File number of the register with the bit to be read. See the RMCLink Register Reference for details.
Element number of the register with the bit to be read. See the RMCLink Register Reference for details.
bit
Number of the bit (0-31) to read in the register. Bits are numbered from least to most significant.
If the bit that was read was 1, then True is returned, otherwise False is returned.
Error Code |
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
One of the file, element, or bit parameters are out of range. |
rmcEDisconnecting = 1002 |
rmcEDisconnected = 1005 |
rmcESocketInternal = 1008 |
rmcECancelled = 1010 |
rmcETimeout = 1011 |
rmcESocketReadError = 1015 |
rmcESocketInvReadLen = 1016 |
rmcESocketWriteError = 1017 |
rmcESerialIOE = 1021 |
Serial IOE error. |
Serial framing error. |
rmcESerialBreak = 1023 |
Serial Break error. |
rmcESerialOverrun = 1024 |
Serial overrun. |
rmcESerialRxOverrun = 1025 |
Serial receive overrun. |
Serial parity error. |
rmcESerialTxFull = 1027 |
Serial transmitter full. |
rmcEConnectionBroken = 1028 |
rmcEPartialWrite = 1029 |
rmcEBadAddress = 1032 |
rmcEUSBInternal1 = 1051 |
rmcEUSBDisconnected = 1054 |
The following code example illustrates the use of the ReadBit method.
' Read bit 0 of L8:0 (Axis 0 In Position)
Dim Value As Boolean
Value = rmc.ReadBit(fn70StatusAxis0, 0, 0)
resultText = "In Position? " & Value
Dim srv, rmc, value
value = rmc.ReadBit(8,0,0)
WScript.Echo "In Position? " & value
// Read bit 0 of L8:0 (Axis 0 In Position)
var value = rmc.ReadBit(8,0,0);
WScript.echo("In Position? " + value);
