RMCLinkServer Class |
Use an instance of this class to create an RMCLink object that will be used to communicate with an RMC.
An RMCLinkServer object must be created using language-specific methods, as shown in the Example section below. Using this object, an RMCLink object is created by the CreateEthernetLink, CreateSerialLink or CreateUSBLink method.
Creates an RMCLink object for communicating with a controller (RMC70, RMC150, RMC200, or RMC100) over Ethernet. |
Creates an RMCLink object for communicating with a controller (RMC70 or RMC100) over a serial port. |
Creates an RMCLink object for communicating with a controller (RMC70, RMC150, or RMC200) over a USB port. |
An RMCLinkServer object is used to create an RMCLink object with either the CreateEthernetLink, CreateSerialLink, or CreateUSBLink method, which specify the type and address (serial port or host name) of the controller you want to connect to. After the RMCLink object has been created, the RMCLinkServer object is not used and can be released. The RMCLink object is then used to open communications, perform communications, and close communications.
The following code example illustrates the basic use of the RMCLinkServer class:
Dim data As Variant
Option Explicit Dim srv, rmc, data ' First we need to create the RMCLinkServer COM object. Set srv = CreateObject("RMCLink.RMCLinkServer") ' Use our RMCLinkServer to create the correct type of RMCLink object. ' NOTE: VBScript does not support enumerations, so we use the literal value (dtRMC70=2). Set rmc = srv.CreateEthernetLink(2, "192.168.0.22") ' Establish the connection. rmc.Connect ' Read F8:8 and F8:9 (Axis 0 Actual Position and Velocity) data = rmc.ReadFFile_Script(8,8,2) WScript.Echo "Actual Position = " & data(0) & ", Actual Velocity = " & data(1) ' Close the connection. rmc.Disconnect |
RMCLink COM Component | RMCLink Class
