RMCLink COM Component RMCLink.IsConnected Method |
Checks to see if the link is currently connected to a controller.
Function IsConnected ( _ ping As PingType _ ) As Boolean |
Dim instance As RMCLink Dim ping As PingType Dim returnValue As Boolean
returnValue = instance.IsConnected(ping) |
ping
This parameter determines if the link should try sending a test communication with the controller before deciding whether the connection is still established. Specify ptPing to do the test communication, and ptDoNotPing to determine if the connection is established based on the last communication attempt. This parameter is ignored if the connection is known to be closed.
Return True if the connection is established (after a ping is sent out if ping is set to ptPing). Otherwise, returns False.
This method is synchronous, which means that it will not return until the method is completed. If ping is ptDoNotPing, then it will return immediately. If ping is ptPing, then it may take several seconds to complete. If this method is called on the main thread, then the application will likely be unresponsive until this method completes. For applications where this is not acceptable, this and other synchronous methods should be called from a worker thread, and may use the CancelRequest method to cancel an in progress request.
Error Code |
rmcEInvalidArg = 7 |
The ping parameter must be ptPing (1) or ptDoNotPing (0). |
The following code example illustrates the use of the IsConnected method.
Option Explicit Public Sub Sample() ' Declare and create the RMCLinkServer COM object. Dim srv As New RMCLinkServer ' Use our RMCLinkServer to create the correct type of RMCLink object. Dim rmc As RMCLink Set rmc = srv.CreateEthernetLink(dtRMC70, "192.168.0.22") ' Establish the connection. rmc.Connect ' Do some long task... ' Check to see if the link is still connected. Dim isConn As Boolean isConn = rmc.IsConnected(ptPing) If (isConn) Then resultText = "Connection is still made." ' Use the connection... ' Close the connection. rmc.Disconnect Else resultText = "Connection has been broken." End If End Sub |
Dim srv, rmc, isConn
' Check to see if the link is still connected. Again we use the literal value
' for the enumeration (ptPing=1).
isConn = rmc.IsConnected(1)
If ( isConn ) Then
WScript.Echo "Connection is still made."
Else
WScript.Echo "Connection has been broken."
End If
// Do some long task...
// Check to see if the link is still connected. Again we use the literal value
// for the enumeration (ptPing=1).
var isConn = rmc.IsConnected(1);
if ( isConn )
WScript.echo("Connection is still made.");
// Use the connection...
else
WScript.echo("Connection has been broken.");
