RMCLink COM Component RMCLinkServer.CreateUSBLink Method |
Creates an RMCLink object for communicating with a controller (RMC70, RMC150, or RMC200) over a USB port.
Function CreateUSBLink ( _ devType As DeviceType, _ deviceId As String _ ) As RMCLink |
Dim instance As RMCLinkServer Dim devType As DeviceType Dim deviceId As String Dim returnValue As RMCLink returnValue = instance.CreateUSBLink(devType, deviceId) |
devType
Specifies which type of RMC will be linked to. It must be either dtRMC70, dtRMC150, or dtRMC200.
deviceID
Specifies which controller to connect to over the USB port:
RMC75E: The controller’s 10-digit serial number in the format ”7573xxyyzz”.
RMC150: The Ethernet (MAC) Address in the format ”00-50-A0-xx-yy-zz”.
RMC200: The CPU module's serial number in the format ”22Cyynnnn”.
Returns a reference to a new RMCLink object created for communicating with the specified device type with the specified deviceId over a USB port.
Notice that this method does not in any way try to connect to the controller. This method simply creates the RMCLink object. To connect to the device, you will need to call the RMCLink.Connect instance method.
Because the object is only created and the connection is not made, this method returns immediately.
Error Code |
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
Invalid argument. Ensure that devType was either dtRMC70, dtRMC150, or dtRMC200 and that deviceId had a valid device ID. |
The following code example illustrates the use of the CreateUSBLink method.
Set rmc = srv.CreateUSBLink(dtRMC70, "7573091001")
Dim data As Variant
Dim srv, rmc, data
Set rmc = srv.CreateUSBLink(2, "7573091001")
var rmc = srv.CreateUSBLink(2, "7573091001");
RMCLinkServer Class | RMCLink Class | RMCLink COM Component
