RMCLink COM Component RMCLink.ReadLFile_Script Method |
Reads one or more integer (L) registers from the controller. This method is only for use in VBScript or JScript. Use the ReadLFile method with other languages. ReadLFile_Script is typically used to read RMC100 registers (which are all integer registers), or to read RMC70, RMC150, or RMC200 registers in integer format.
Function ReadLFile_Script ( _ file As Long, _ element As Long, _ count As Long _ ) As Variant |
Dim instance As RMCLink Dim file As Long Dim element As Long Dim count As Long Dim returnValue As Variant
returnValue = instance.ReadLFile_Script(file, element, count) |
count
The number of registers to read.
This variant will be filled with the data read from the controller. The variant data type will be a single-dimension 0-based array of Variant elements, each which in turn holds a Long. The length is determined by count.
The only difference between ReadLFile_Script and ReadLFile is the format of the data returned in the Variant return value. For ReadLFile, the Variant holds a single-dimension 0-based array of Long elements. For ReadLFile_Script, the Variant holds a single-dimension 0-based array of Variant elements, and each Variant element in turn holds a Long. This extra layer of indirection is required by some scripting languages (VBScript and JScript, for example), but is other less efficient and should be avoided when ReadLFile is supported by your language.
Notice that JScript arrays are not directly compatible with the arrays returned by ReadLFile_Script. Therefore, before using the array elements, you must call JScript's toArray method on the variable returned by ReadLFile_Script. See the JScript example below.
Error Code |
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
One of the file, element, or counts parameters are out of range. |
rmcEDisconnecting = 1002 |
rmcEDisconnected = 1005 |
rmcESocketInternal = 1008 |
rmcECancelled = 1010 |
rmcETimeout = 1011 |
rmcESocketReadError = 1015 |
rmcESocketInvReadLen = 1016 |
rmcESocketWriteError = 1017 |
rmcESerialIOE = 1021 |
Serial IOE error. |
Serial framing error. |
rmcESerialBreak = 1023 |
Serial Break error. |
rmcESerialOverrun = 1024 |
Serial overrun. |
rmcESerialRxOverrun = 1025 |
Serial receive overrun. |
Serial parity error. |
rmcESerialTxFull = 1027 |
Serial transmitter full. |
rmcEConnectionBroken = 1028 |
rmcEPartialWrite = 1029 |
rmcEBadAddress = 1032 |
rmcEUSBInternal1 = 1051 |
rmcEUSBDisconnected = 1054 |
The following code example illustrates the use of the ReadLFile_Script method.
Dim srv, rmc, data
' NOTE: VBScript does not support enumerations, so we use the literal value (dtRMC100=1).
Set rmc = srv.CreateEthernetLink(1, "192.168.0.28")
' Read L0:1-2 (Axis 0 Target and Actual Positions)
data = rmc.ReadLFile_Script(0,1,2)
WScript.Echo "Target Pos. = " & data(0) & ", Actual Pos. = " & data(1)
// NOTE: JScript does not support enumerations, so we use the literal value (dtRMC100=1).
var rmc = srv.CreateEthernetLink(1, "192.168.0.28");
// Read L0:1-2 (Axis 0 Target and Actual Positions)
var data = rmc.ReadLFile_Script(0,1,2).toArray();
WScript.echo("Target Pos. = " + data[0] + ", Actual Pos. = " + data[1]);
RMCLink Class | RMCLink COM Component | ReadLFile | ReadFFile_Script
