RMCLink COM Component RMCLink.ReadBitField Method |
Reads a bit field (range of bits) from an integer (L) register in the RMC, and converts the binary value of the bits to a long integer. ReadBitField is typically used to read the value of a multiple-bit parameter in the RMC70, RMC150, or RMC200.
Function ReadBitField ( _ file As Long, _ element As Long, _ fieldStart As Long, _ fieldLen As Long _ ) As Long |
Dim instance As RMCLink Dim file As Long Dim element As Long Dim fieldStart As Long Dim fieldLen As Long Dim returnValue As Long
returnValue = instance.ReadBitField(file, element, fieldStart, fieldLen) |
File number of the register with the bit to be read. See the RMCLink Register Reference for details.
Element number of the register with the bit to be read. See the RMCLink Register Reference for details.
fieldStart
Number of the least significant bit (0-31) of the register's bit field. Bits are numbered from least to most significant.
fieldLen
Total number of bits in the bit field (1-32).
The value of the bit field is returned.
Error Code |
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
One of the file, element, fieldStart, or fieldLen parameters are out of range. |
rmcEDisconnecting = 1002 |
rmcEDisconnected = 1005 |
rmcESocketInternal = 1008 |
rmcECancelled = 1010 |
rmcETimeout = 1011 |
rmcESocketReadError = 1015 |
rmcESocketInvReadLen = 1016 |
rmcESocketWriteError = 1017 |
rmcESerialIOE = 1021 |
Serial IOE error. |
Serial framing error. |
rmcESerialBreak = 1023 |
Serial Break error. |
rmcESerialOverrun = 1024 |
Serial overrun. |
rmcESerialRxOverrun = 1025 |
Serial receive overrun. |
Serial parity error. |
rmcESerialTxFull = 1027 |
Serial transmitter full. |
rmcEConnectionBroken = 1028 |
rmcEPartialWrite = 1029 |
rmcEBadAddress = 1032 |
rmcEUSBInternal1 = 1051 |
rmcEUSBDisconnected = 1054 |
The following code example illustrates the use of the ReadBitField method.
' Read bits 10-11 of L8:0 (Axis 0 Target State bits A and B)
Dim Value As Long
Value = rmc.ReadBitField(fn70StatusAxis0, 0, 10, 2)
resultText = "Target State = " & Value
Dim srv, rmc, value
value = rmc.ReadBitField(8,0,10,2)
WScript.Echo "Target State = " & value
// Read bits 10-11 of L8:0 (Axis 0 Target State bits A and B)
var value = rmc.ReadBitField(8,0,10,2);
WScript.echo("Target State = " + value);
