How to: Use from JScript |
JScript users use the RMCLink COM Component interface. Specifics on using this component from JScript are described below, including a complete example script. The example script is also included as a JScript project in the RMCLink example projects.
As is common for all languages, the first step is to create an instance of the RMCLink class. This is a two step process: first create an RMCLinkServer object, and then use that object to create the appropriate type of RMCLink object.
To create the RMCLinkServer object, use the following line in your JScript file:
You can now use the newly created srv variable to create the RMCLink object using one of RMCLinkServer's CreateEthernetLink, CreateSerialLink or CreateUSBLink methods. The following line creates a link for communicating with an RMC70 at IP address 192.168.0.22:
Notice that as described below, JScript cannot use enumerations, and therefore, although the CreateEthernetLink, CreateSerialLink and CreateUSBLink methods take a DeviceType parameter, the literal value for the desired enumeration must be used.
JScript cannot use enumerations. Therefore, although the CreateEthernetLink, CreateSerialLink and CreateUSBLink methods are specified to have the devType parameter be of type DeviceType, you must enter the literal value of the enumeration member you want to use. Similarly, for the IsConnected method's ping parameter, you will have to use the literal values in place of the PingType enumeration members. Each enumeration topic lists the literal values next to the named values (e.g. ptDoNotPing = 0).
Because of the requirements that JScript has on using arrays passed back to it from COM components, you must not use ReadFFile or ReadLFile; use ReadFFile_Script or ReadLFile_Script instead. The first two functions will appear to work, but you will not be able to access the elements in the returned array later in your program.
Also, JScript arrays are not the same as COM's "safe arrays" that are returned from ReadFFile_Script and ReadLFile_Script, and therefore, you must convert from a COM safe array to a JScript array before the array elements can be accessed. This is done by calling the toArray method on the data itself, as shown:
var dataCOMArray = rmc.ReadFFile_Script(8,8,2);
var dataArray = dataCOMArray.toArray();
These two steps can also be combined into a single line:
Notice that the ReadBit and ReadBitField methods can be used as well and have no JScript issues.
The WriteFFile and WriteLFile methods can be used normally. They need to be passed a JScript array with the same length as the count parameter. Refer to these method's topics for an example.
Notice that in addition to the example below, most method topics include an example in JScript as well. These can be used if you have particular difficulty making one or another method work in JScript.
The following code is an example of a JScript program. This example script is also included as a JScript project in the RMCLink example projects.
JScript (Sample.js) |
RMCLink COM Component | How Do I Overview | RMCLink Component
