RMCLink COM Component Enumerations |
These enumerations are available for use with the RMCLink COM Component in order to improve program readability.
NOTE: VBScript and JScript do not support using enumerated constants, and therefore you will have to manually type in the numbers instead of the constant names for those languages.
Miscellaneous constants for use when communicating with the RMC70. These are typically used when computing file, element, of count parameters in read or write methods. |
Miscellaneous constants for use when communicating with the RMC150. These are typically used when computing file, element, of count parameters in read or write methods. |
Miscellaneous constants for use when communicating with the RMC200. These are typically used when computing file, element, of count parameters in read or write methods. |
Miscellaneous constants for use when communicating with the RMC100. These are typically used when computing file, element, of count parameters in read or write methods. |
Constants used by RMCLinkServer.CreateEthernetLink, RMCLinkServer.CreateSerialLink and RMCLinkServer.CreateUSBLink to select which type of controller will be connected to the link. |
File numbers used when communicating with the RMC70. These are often used as the file parameter in read and write methods. |
File numbers used when communicating with the RMC150. These are often used as the file parameter in read and write methods. |
File numbers used when communicating with the RMC200. These are often used as the file parameter in read and write methods. |
File numbers used when communicating with the RMC100. These are often used as the file parameter in read and write methods. |
Constants are used to select whether the RMCLink.IsConnected method will try pinging the device before returning to verify that the link is still connected. |
Error values for the COM exceptions that can be thrown by the RMCLink COM component. |
