Constants200 Enumeration |
Miscellaneous constants for use when communicating with the RMC200. These are typically used when computing file, element, of count parameters.
rmc200CmdRegsPerAxis = 10 |
For calculating the element parameter when writing to the fn200CommandArea file. |
RMCLink COM Component | Enumeration Types
