Constants70 Enumeration |
Miscellaneous constants for use when communicating with the RMC70. These are typically used when computing file, element, of count parameters.
rmc70CmdRegsPerAxis = 6 |
For calculating the element parameter when writing to the fn70CommandArea file. |
rmc70LrgCmdRegsPerAxis = 10 |
For calculating the element parameter when writing to the fn70LrgCommandArea file. |
RMCLink COM Component | Enumeration Types
