RMCLinkError Enumeration |
These constants represent the values of the COM exceptions that can be thrown by the RMCLink COM component.
How errors are communicated back to the calling program varies by language. Visual Basic 5.0/6.0, VBA, and VBScript all invoke the current error handler which can be set up using the On Error statement and Err object. JScript throws a generic exception that can be handled using a try-catch block. LabVIEW returns the error in the error out node. See the Error Handling topic for details on handling errors.
NOTE: For JScript, the Number property of the Error object in the caught exception will not match the values below, but will have the value 2,146,828,288 subtracted from it. That is, instead of the value 5 for an out of memory condition, the Error.Number will be -2,146,828,283.
NOTE: For LabVIEW, the error out will not match the values below, but will have the value 2,146,828,288 subtracted from it. That is, instead of the value 5 for an out of memory condition, the error out will be -2,146,828,283.
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
Invalid argument or procedure call. |
rmcEAlreadyLocked = 1001 |
Internal RMCLink locking error. |
rmcEDisconnecting = 1002 |
rmcEBadType = 1003 |
Invalid type passed in for write data. |
rmcEBadLength = 1004 |
Array length of write data does not match count parameter. |
rmcEDisconnected = 1005 |
rmcEAlreadyConnected = 1006 |
The link was already connected. |
rmcEAlreadyDisconnected = 1007 |
The link was already disconnected. |
rmcESocketInternal = 1008 |
rmcESocketConnectionFailure = 1009 |
Unable to connect over TCP/IP to requested device. |
rmcECancelled = 1010 |
rmcETimeout = 1011 |
rmcESocketHostNameNotIPv4 = 1012 |
Host name did not resolve to an IPv4 address. |
rmcESocketHostNameNotResolved = 1013 |
Host name did not resolve. |
rmcESocketReadError = 1015 |
rmcESocketInvReadLen = 1016 |
rmcESocketWriteError = 1017 |
rmcEPortAccessDenied = 1019 |
Access to serial port denied. Verify not in use by another application. |
rmcEPortNotFound = 1020 |
Serial port not found. |
rmcESerialIOE = 1021 |
Serial IOE error. |
Serial framing error. |
rmcESerialBreak = 1023 |
Serial Break error. |
rmcESerialOverrun = 1024 |
Serial overrun. |
rmcESerialRxOverrun = 1025 |
Serial receive overrun. |
Serial parity error. |
rmcESerialTxFull = 1027 |
Serial transmitter full. |
rmcEConnectionBroken = 1028 |
rmcEPartialWrite = 1029 |
rmcEReadOnly = 1030 |
Attempt to write to read-only registers. |
rmcEPrivateRange = 1031 |
Attempt to read/write from private registers. |
rmcEBadAddress = 1032 |
rmcESocketHostnameInvalid = 1033 |
Invalid host name format. |
rmcEWrongController = 1034 |
Remote device is the wrong controller type. |
rmcENotSupported = 1035 |
Operation not supported on this controller type. |
rmcEBuildImgTimeout = 1036 |
Timeout waiting for image to be built. |
rmcEBuildImgError = 1037 |
Controller unable to build image. |
rmcEBuildImgState = 1038 |
Unexpected state encountered while building image. |
rmcEImageUploadFailed = 1039 |
Unable to upload completed image. |
rmcEImageResetFailed = 1040 |
Unable to reset Image Area for download. |
rmcEImageDownloadFailed = 1041 |
Unable to download controller image. |
rmcEImageInvalid = 1042 |
Timeout applying downloaded image. |
rmcEImageApplyTimeout = 1043 |
Image format is invalid. |
rmcEImageApplyState = 1044 |
Unexpected state encountered while applying image. |
rmcEImageApplyResetReq = 1045 |
Image not applied because restart required. |
rmcEImageApplyFlashError = 1046 |
Error writing to flash memory while applying image. |
rmcEImageApplyRunMode = 1047 |
Image cannot be applied without restart while in RUN mode. |
rmcEImageApplyHWMismatch = 1048 |
Image not applied because of hardware mismatch. |
rmcEUSBNoDrivers = 1049 |
Unable to access RMC USB driver. Please ensure that the driver has been properly installed. |
rmcEUSBDeviceNotFound = 1050 |
The controller with the specified DeviceId was not found on any USB port. |
rmcEUSBInternal1 = 1051 |
rmcEUSBInternal2 = 1052 |
rmcEUSBDisconnected = 1054 |
rmcEUSBUnknownFailure = 1055 |
The requested RMC is plugged into a USB port, but cannot be accessed. Ensure that no other applications are using this RMC. If the problem persists, try unplugging and re-plugging the USB cable to this controller and retry. |
rmcEUSBInUse = 1056 |
rmcEUSBNoSetupAPI = 1057 |
Unable to access operating system functionality for connecting to USB devices. |
rmcEFileNotFound = 1058 |
Unable the find the specified file. |
rmcEPathNotFound = 1059 |
Unable the find the specified file path. |
rmcEAccessDenied = 1060 |
Access denied to the file or path. |
rmcEDriveNotReady = 1061 |
Removable drive not ready. |
rmcEBuildImgNotAllowed = 1062 |
Controller unable to build upload image because copy protection is enabled. |
rmcEUnknown = 1999 |
Unknown control error. |
RMCLink COM Component | Enumeration Types | Error Handling
