FileNumber100 Enumeration |
These constants are file numbers used when communicating to the RMC100. These are often used as the file parameter in read and write methods.
fn100StatusAxis0 = 0 |
Axis 0 Status Registers (10 elements) |
fn100StatusAxis1 = 1 |
Axis 1 Status Registers (10 elements) |
fn100StatusAxis2 = 2 |
Axis 2 Status Registers (10 elements) |
fn100StatusAxis3 = 3 |
Axis 3 Status Registers (10 elements) |
fn100StatusAxis4 = 4 |
Axis 4 Status Registers (10 elements) |
fn100StatusAxis5 = 5 |
Axis 5 Status Registers (10 elements) |
fn100StatusAxis6 = 6 |
Axis 6 Status Registers (10 elements) |
fn100StatusAxis7 = 7 |
Axis 7 Status Registers (10 elements) |
fn100CommandAxis0 = 8 |
Axis 0 Command Registers (6 elements) |
fn100CommandAxis1 = 9 |
Axis 1 Command Registers (6 elements) |
fn100CommandAxis2 = 10 |
Axis 2 Command Registers (6 elements) |
fn100CommandAxis3 = 11 |
Axis 3 Command Registers (6 elements) |
fn100CommandAxis4 = 12 |
Axis 4 Command Registers (6 elements) |
fn100CommandAxis5 = 13 |
Axis 5 Command Registers (6 elements) |
fn100CommandAxis6 = 14 |
Axis 6 Command Registers (6 elements) |
fn100CommandAxis7 = 15 |
Axis 7 Command Registers (6 elements) |
fn100ParameterAxis0 = 16 |
Axis 0 Parameter Registers (16 elements) |
fn100ParameterAxis1 = 17 |
Axis 1 Parameter Registers (16 elements) |
fn100ParameterAxis2 = 18 |
Axis 2 Parameter Registers (16 elements) |
fn100ParameterAxis3 = 19 |
Axis 3 Parameter Registers (16 elements) |
fn100ParameterAxis4 = 20 |
Axis 4 Parameter Registers (16 elements) |
fn100ParameterAxis5 = 21 |
Axis 5 Parameter Registers (16 elements) |
fn100ParameterAxis6 = 22 |
Axis 6 Parameter Registers (16 elements) |
fn100ParameterAxis7 = 23 |
Axis 7 Parameter Registers (16 elements) |
fn100StepTable = 24 |
Step Table (2048 elements: 256 steps with 8 elements each) |
fn100I2ERisingEdges = 25 |
Input-to-Event Table, Rising Edges (128 elements: 16 inputs with 8 elements (1 per axis) each) |
fn100I2EFallingEdges = 26 |
Input-to-Event Table, Falling Edges (128 elements: 16 inputs with 8 elements (1 per axis) each) |
fn100StatusMap = 27 |
Status Map (Modbus Plus and PROFIBUS only) (32 elements) |
fn100ProfileTable = 28 |
Profile Table (64 elements: 16 profiles with 4 elements each) |
fn100PlotType = 29 |
Plot Type (8 elements: one per axis) |
fn100DIORegs = 30 |
Discrete I/O Image (8 elements) |
fn100PlotTime = 31 |
Plot Time (8 elements: one per axis) |
fn100ParamError = 32 |
Last Parameter Error (8 elements: one per axis) |
fn100FWRev = 33 |
Firmware Revision Information |
fn100SplineDA = 34 |
Spline Download Area |
fn100PlotAxis0Set0 = 208 |
Axis 0 Plot, Target Position Set (1024 elements) |
fn100PlotAxis0Set1 = 209 |
Axis 0 Plot, Actual Position Set (1024 elements) |
fn100PlotAxis0Set2 = 210 |
Axis 0 Plot, Drive Set (1024 elements) |
fn100PlotAxis0Set3 = 211 |
Axis 0 Plot, Status Bits Set (1024 elements) |
fn100PlotAxis0Set4 = 212 |
Axis 0 Plot, Extra Data #1 Set (1024 elements) |
fn100PlotAxis0Set5 = 213 |
Axis 0 Plot, Extra Data #2 Set (1024 elements) |
fn100PlotAxis1Set0 = 214 |
Axis 1 Plot, Target Position Set (1024 elements) |
fn100PlotAxis1Set1 = 215 |
Axis 1 Plot, Actual Position Set (1024 elements) |
fn100PlotAxis1Set2 = 216 |
Axis 1 Plot, Drive Set (1024 elements) |
fn100PlotAxis1Set3 = 217 |
Axis 1 Plot, Status Bits Set (1024 elements) |
fn100PlotAxis1Set4 = 218 |
Axis 1 Plot, Extra Data #1 Set (1024 elements) |
fn100PlotAxis1Set5 = 219 |
Axis 1 Plot, Extra Data #2 Set (1024 elements) |
fn100PlotAxis2Set0 = 220 |
Axis 2 Plot, Target Position Set (1024 elements) |
fn100PlotAxis2Set1 = 221 |
Axis 2 Plot, Actual Position Set (1024 elements) |
fn100PlotAxis2Set2 = 222 |
Axis 2 Plot, Drive Set (1024 elements) |
fn100PlotAxis2Set3 = 223 |
Axis 2 Plot, Status Bits Set (1024 elements) |
fn100PlotAxis2Set4 = 224 |
Axis 2 Plot, Extra Data #1 Set (1024 elements) |
fn100PlotAxis2Set5 = 225 |
Axis 2 Plot, Extra Data #2 Set (1024 elements) |
fn100PlotAxis3Set0 = 226 |
Axis 3 Plot, Target Position Set (1024 elements) |
fn100PlotAxis3Set1 = 221 |
Axis 3 Plot, Actual Position Set (1024 elements) |
fn100PlotAxis3Set2 = 228 |
Axis 3 Plot, Drive Set (1024 elements) |
fn100PlotAxis3Set3 = 229 |
Axis 3 Plot, Status Bits Set (1024 elements) |
fn100PlotAxis3Set4 = 230 |
Axis 3 Plot, Extra Data #1 Set (1024 elements) |
fn100PlotAxis3Set5 = 231 |
Axis 3 Plot, Extra Data #2 Set (1024 elements) |
fn100PlotAxis4Set0 = 232 |
Axis 4 Plot, Target Position Set (1024 elements) |
fn100PlotAxis4Set1 = 233 |
Axis 4 Plot, Actual Position Set (1024 elements) |
fn100PlotAxis4Set2 = 234 |
Axis 4 Plot, Drive Set (1024 elements) |
fn100PlotAxis4Set3 = 235 |
Axis 4 Plot, Status Bits Set (1024 elements) |
fn100PlotAxis4Set4 = 236 |
Axis 4 Plot, Extra Data #1 Set (1024 elements) |
fn100PlotAxis4Set5 = 237 |
Axis 4 Plot, Extra Data #2 Set (1024 elements) |
fn100PlotAxis5Set0 = 238 |
Axis 5 Plot, Target Position Set (1024 elements) |
fn100PlotAxis5Set1 = 239 |
Axis 5 Plot, Actual Position Set (1024 elements) |
fn100PlotAxis5Set2 = 240 |
Axis 5 Plot, Drive Set (1024 elements) |
fn100PlotAxis5Set3 = 241 |
Axis 5 Plot, Status Bits Set (1024 elements) |
fn100PlotAxis5Set4 = 242 |
Axis 5 Plot, Extra Data #1 Set (1024 elements) |
fn100PlotAxis5Set5 = 243 |
Axis 5 Plot, Extra Data #2 Set (1024 elements) |
fn100PlotAxis6Set0 = 244 |
Axis 6 Plot, Target Position Set (1024 elements) |
fn100PlotAxis6Set1 = 245 |
Axis 6 Plot, Actual Position Set (1024 elements) |
fn100PlotAxis6Set2 = 246 |
Axis 6 Plot, Drive Set (1024 elements) |
fn100PlotAxis6Set3 = 247 |
Axis 6 Plot, Status Bits Set (1024 elements) |
fn100PlotAxis6Set4 = 248 |
Axis 6 Plot, Extra Data #1 Set (1024 elements) |
fn100PlotAxis6Set5 = 249 |
Axis 6 Plot, Extra Data #2 Set (1024 elements) |
fn100PlotAxis7Set0 = 250 |
Axis 7 Plot, Target Position Set (1024 elements) |
fn100PlotAxis7Set1 = 251 |
Axis 7 Plot, Actual Position Set (1024 elements) |
fn100PlotAxis7Set2 = 252 |
Axis 7 Plot, Drive Set (1024 elements) |
fn100PlotAxis7Set3 = 253 |
Axis 7 Plot, Status Bits Set (1024 elements) |
fn100PlotAxis7Set4 = 254 |
Axis 7 Plot, Extra Data #1 Set (1024 elements) |
fn100PlotAxis7Set5 = 255 |
Axis 7 Plot, Extra Data #2 Set (1024 elements) |
RMCLink COM Component | Enumeration Types
