RMCLink.Interop .NET Assembly RMCLinkNET Namespace |
The RMCLink.Interop .NET assembly includes a single namespace: RMCLinkNET. This namespace includes the following classes and enumerations. Notice that RMCLink is the main class that will be used and all other classes and enumeration types simply support this main class.
Class |
This exception will be thrown by the RMCLink.Connect method or any Read or Write method if the operation is cancelled by a call to RMCLink.CancelRequest on another thread. |
This exception can be thrown by the RMCLink.Connect method to indicate that the connection could not be established. |
This exception will be thrown by any Read or Write method that has a communication failure while trying to process its request. |
This class is used to link to RMC controllers to allow reading information from the controller and writing data to the controller. |
Enumeration |
Miscellaneous constants for use when communicating with the RMC70. |
Miscellaneous constants for use when communicating with the RMC150. |
Miscellaneous constants for use when communicating with the RMC200. |
Miscellaneous constants for use when communicating with the RMC100. |
These constants are used when calling RMCLink.CreateEthernetLink, RMCLink.CreateSerialLink and RMCLink.CreateUSBLink to select which type of controller will be connected to the link |
File numbers used when communicating with the RMC70. |
File numbers used when communicating with the RMC150. |
File numbers used when communicating with the RMC200. |
File numbers used when communicating with the RMC100. |
These two constants are used to select whether the RMCLink.IsConnected method will try pinging the device before returning to verify that the link is still connected. |
