RMCLink.Interop .NET Assembly RMCLink.CancelRequest Method |
This method can be used in multi-threaded applications to cancel the currently-in-progress read, write, or connect request.
Public Sub CancelRequest |
Dim instance As RMCLink
instance.CancelRequest() |
public void CancelRequest () |
public: void CancelRequest () |
This method is only for use in multi-threaded applications.
This method signals the current read, write, or connection attempt (if one is in progress) to throw a CancelledException, and then returns immediately. Notice that the CancelledException may be thrown on the transaction's thread before or after this method returns on its thread. If no transaction is in progress when this method is called, then this method will do nothing and return.
This method affects, at most, one transaction (read, write, or connection attempt), so requests made after this method returns will behave normally.
No exceptions are generated by this method.
The following code example illustrates the use of the CancelRequest method.
Imports System.Threading
' Assumes that the form contains the following controls:
' buttonRead - Button labeled "Read Position".
' buttonCancel - Button labeled "Cancel" (defaults disabled).
' textBoxActPos - Read-only TextBox that displays Axis 0 Actual Position.
' textBoxStatus - Read-only TextBox that displays results of the read.
Public Class TestForm
Private Sub buttonRead_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles buttonRead.Click
If (Not isReadInProgress) Then
myRmc = RMCLink.CreateEthernetLink(DeviceType.RMC70, "192.168.0.10")
isReadInProgress = True
' Disable the Read button and enable the Cancel button.
buttonRead.Enabled = False
buttonCancel.Enabled = True
' Start the Thread that will do the read.
Dim worker As Thread = New Thread(New ThreadStart(AddressOf doUpdate))
worker.Name = "Worker"
worker.Start()
End If
Private Sub buttonCancel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles buttonRead.Click
If (isReadInProgress) Then
If (Not myRmc Is Nothing) Then
myRmc.CancelRequest()
End If
End If
Private Sub doUpdate()
Try
Try
textBoxStatus.Text = "Connecting..."
myRmc.Connect()
Try
textBoxStatus.Text = "Reading..."
myRmc.ReadFFile(FileNumber70.fn70StatusAxis0, 8, data, 0, 1)
textBoxActPos.Text = String.Format("{0:F3}", data(0))
textBoxStatus.Text = "Read successful."
Finally
myRmc.Disconnect()
End Try
Catch ex As ConnectionNotMadeException
textBoxStatus.Text = "Unable to connect."
MessageBox.Show("Unable to connect to the controller. " + ex.Message)
Catch ex As ReadWriteFailedException
textBoxStatus.Text = "Read failed."
MessageBox.Show("Unable to read from the controller. " + ex.Message)
Catch ex As CancelledException
textBoxStatus.Text = "Read Cancelled."
End Try
Finally
isReadInProgress = False
buttonRead.Enabled = True
buttonCancel.Enabled = False
End Try
Private myRmc As RMCLink = Nothing
Private isReadInProgress As Boolean = False
End Class
using System.Windows.Forms;
using System.Threading;
// Assumes that the form contains the following controls:
// buttonRead - Button labeled "Read Position".
// buttonCancel - Button labeled "Cancel" (defaults disabled).
// textBoxActPos - Read-only TextBox that displays Axis 0 Actual Position.
// textBoxStatus - Read-only TextBox that displays results of the read.
public partial class TestForm : Form
private void buttonRead_Click(object sender, EventArgs e)
if ( ! isReadInProgress)
myRmc = RMCLink.CreateEthernetLink(DeviceType.RMC70, "192.168.0.10");
isReadInProgress = true;
// Disable the Read button and enable the Cancel button.
buttonRead.Enabled = false;
buttonCancel.Enabled = true;
// Start the Thread that will do the read.
Thread worker = new Thread(new ThreadStart(doUpdate));
worker.Name = "Worker";
worker.Start();
private void buttonCancel_Click(object sender, EventArgs e)
if (isReadInProgress)
if (myRmc != null)
myRmc.CancelRequest();
private void doUpdate()
try
try
textBoxStatus.Text = "Connecting...";
myRmc.Connect();
try
float[] data = new float[1];
textBoxStatus.Text = "Reading...";
myRmc.ReadFFile((int)FileNumber70.fn70StatusAxis0, 8, data, 0, 1);
textBoxActPos.Text = String.Format("{0:F3}", data[0]);
textBoxStatus.Text = "Read successful.";
finally
myRmc.Disconnect();
catch (ConnectionNotMadeException e)
textBoxStatus.Text = "Unable to connect.";
MessageBox.Show("Unable to connect to the controller. " + e.Message);
catch (ReadWriteFailedException e)
textBoxStatus.Text = "Read failed.";
MessageBox.Show("Unable to read from the controller. " + e.Message);
catch (CancelledException)
textBoxStatus.Text = "Read Cancelled.";
finally
isReadInProgress = false;
buttonRead.Enabled = true;
buttonCancel.Enabled = false;
private RMCLink myRmc = null;
private bool isReadInProgress = false;
namespace RMCLinkNETVCPPSampleUI
using namespace System::ComponentModel;
using namespace System::Windows::Forms;
using namespace System::Threading;
public ref class Form1 : public System::Windows::Forms::Form
public:
Form1(void) : myRmc(nullptr), isReadInProgress(false)
InitializeComponent();
private:
System::Void buttonRead_Click(System::Object^ sender, System::EventArgs^ e)
myRmc = RMCLink::CreateEthernetLink(DeviceType::RMC70, "192.168.0.10");
buttonRead->Enabled = false;
buttonCancel->Enabled = true;
// Start a Thread to do the work.
Thread^ worker = gcnew Thread(gcnew ThreadStart(this, &Form1::doUpdate));
worker->Name = "Worker";
worker->Start();
System::Void buttonCancel_Click(System::Object^ sender, System::EventArgs^ e)
if (myRmc != nullptr)
myRmc->CancelRequest();
System::Void doUpdate(System::Void)
try
try
textBoxStatus->Text = "Connecting...";
myRmc->Connect();
try
textBoxStatus->Text = "Reading...";
myRmc->ReadFFile((int)FileNumber70::fn70StatusAxis0, 8, data, 0, 1);
textBoxActPos->Text = String::Format("{0:F3}", data[0]);
textBoxStatus->Text = "Read successful.";
finally
myRmc->Disconnect();
catch (ConnectionNotMadeException^ e)
textBoxStatus->Text = "Unable to connect.";
MessageBox::Show("Unable to connect to the controller. " + e->Message);
catch (ReadWriteFailedException^ e)
textBoxStatus->Text = "Read failed.";
MessageBox::Show("Unable to read from the controller. " + e->Message);
catch (CancelledException^)
textBoxStatus->Text = "Read Cancelled.";
finally
buttonRead->Enabled = true;
buttonCancel->Enabled = false;
RMCLink^ myRmc;
bool isReadInProgress;
