RMCLink.Interop .NET Assembly RMCLink.CreateSerialLink Method |
Creates an RMCLink object for communicating with a controller (either RMC70 or RMC100) over a serial port.
Public Shared Function CreateSerialLink ( _ devType As DeviceType, _ portName As String _ ) As RMCLink |
Dim devType As DeviceType Dim portName As String Dim returnValue As RMCLink
returnValue = RMCLink.CreateSerialLink(devType, portName) |
public static RMCLink CreateSerialLink ( DeviceType devType, string portName ) |
public: static RMCLink^ CreateSerialLink ( DeviceType devType, String^ portName ) |
devType
Specifies which type of RMC will be linked to. It must be either DeviceType.RMC70 or DeviceType.RMC100.
portName
Specifies the serial port to use for communicating with the device. Typical names include "COM1" and "COM2".
Returns a reference to a new RMCLink object created for communicating with the specified device type on the specified serial port.
Notice that this method does not in any way try to connect to the controller. This method simply creates the RMCLink object. To connect to the device, you will need to call the Connect instance method. This method will support any com port on the PC.
Because the object is only created and the connection is not made, this method returns immediately.
Exception Type |
Condition |
The portName parameter refers to a null (Nothing in Visual Basic) object. |
Either the devType parameter is set to neither DeviceType.RMC70 nor DeviceType.RMC100, or the portName parameter is blank. |
The following code example illustrates the use of the CreateSerialLink method.
' Read and display Axis 0's Actual Position (F8:8).
rmc.ReadFFile(FileNumber70.fn70StatusAxis0,8,data,0,1)
Console.WriteLine("Axis0 Actual Position = " & data(0) & " inches")
// Create the object itself.
// Read and display Axis 0's Actual Position.
float[] data = new float[1];
rmc.ReadFFile(FileNumber70.fn70StatusAxis0,8,data,0,1);
Console.WriteLine("Axis0 Actual Position = " + data[0] + " inches");
rmc->ReadFFile(FileNumber70::fn70StatusAxis0,8,data,0,1);
Console::WriteLine("Axis0 Actual Position = " + data[0] + " inches");
RMCLink.Interop .NET Assembly | RMCLinkNET Namespace | RMCLink Class | DeviceType
