RMCLink.Interop .NET Assembly RMCLink.CreateUSBLink Method |
Creates an RMCLink object for communicating with a controller (RMC70, RMC150, or RMC200) over a USB port.
Public Shared Function CreateUSBLink ( _ devType As DeviceType, _ deviceId As String _ ) As RMCLink |
Dim devType As DeviceType Dim deviceId As String Dim returnValue As RMCLink
returnValue = RMCLink.CreateUSBLink(devType, deviceId) |
public static RMCLink CreateUSBLink ( DeviceType devType, string deviceId ) |
public: static RMCLink^ CreateUSBLink ( DeviceType devType, String^ deviceId ) |
devType
Specifies which type of RMC will be linked to. It must be either DeviceType.RMC70, DeviceType.RMC150, or DeviceType.RMC200.
deviceId
Specifies which controller to connect to over the USB port:
RMC75E: The controller’s 10-digit serial number in the format ”7573xxyyzz”.
RMC150: The Ethernet (MAC) Address in the format ”00-50-A0-xx-yy-zz”.
RMC200: The CPU module's serial number in the format ”22Cyynnnn”.
Returns a reference to a new RMCLink object created for communicating with the specified device type with the specified deviceId over a USB port.
Notice that this method does not in any way try to connect to the controller. This method simply creates the RMCLink object. To connect to the device, you will need to call the Connect instance method.
Because the object is only created and the connection is not made, this method returns immediately.
Exception Type |
Condition |
The deviceId parameter refers to a null (Nothing in Visual Basic) object. |
Either the devType parameter is set to neither DeviceType.RMC70, DeviceType.RMC150, nor DeviceType.RMC200, or the deviceId parameter is blank. |
The following code example illustrates the use of the CreateUSBLink method.
Dim rmc As RMCLink = RMCLink.CreateUSBLink(DeviceType.RMC70, "7573091001")
' Read and display Axis 0's Actual Position (F8:8).
rmc.ReadFFile(FileNumber70.fn70StatusAxis0,8,data,0,1)
Console.WriteLine("Axis0 Actual Position = " & data(0) & " inches")
// Create the object itself.
RMCLink rmc = RMCLink.CreateUSBLink(DeviceType.RMC70, "7573091001");
// Read and display Axis 0's Actual Position.
float[] data = new float[1];
rmc.ReadFFile(FileNumber70.fn70StatusAxis0,8,data,0,1);
Console.WriteLine("Axis0 Actual Position = " + data[0] + " inches");
RMCLink^ rmc = RMCLink::CreateUSBLink(DeviceType::RMC70, "7573091001");
rmc->ReadFFile(FileNumber70::fn70StatusAxis0,8,data,0,1);
Console::WriteLine("Axis0 Actual Position = " + data[0] + " inches");
RMCLink.Interop .NET Assembly | RMCLinkNET Namespace | RMCLink Class | DeviceType
