RMCLink.Interop .NET Assembly RMCLink.WriteImage Method |
Writes the specified controller image to the controller and applies it to the controller. By default, the image will be saved to flash and the controller will be restarted. The controller image must be obtained using the ReadImage method. For saving and restoring the controller image using a file, use the ReadImageToFile and WriteImageFromFile methods. This method is only supported on the RMC75E, RMC150E, and RMC200 controllers.
Public Sub WriteImage ( _ flags As Integer, _ data() As Integer ) |
Dim instance As RMCLink Dim flags As Integer Dim data() As Integer
instance.WriteImage(flags, data) |
public void WriteImage ( int flags, int[] data ) |
public: void WriteImage ( int flags array<int>^ data ) |
flags
Options to use when applying the image. Refer to the RMCTools documentation on the Image Area for a current list of options. As of this writing, a single option has been defined. Specify zero (0) to use default options.
+0 |
Save Image to Flash, and Restart Controller to Apply |
+16 |
Apply Image Immediately and Save To Flash (not supported by RMC200) |
data
An array of Integer values containing the controller image. The data must have been created using the ReadImage method.
Exception Type |
Condition |
The data parameter refers to a null (Nothing in Visual Basic) object. |
The flags parameter is out of range. |
One of the following circumstances occurred:
The write failed due to a communication failure. Check that the remote device is powered up, check the communication wiring, and check the communication configuration of both the local and remote devices. Check the Message property of the exception for a description of the communication failure. |
The following code example illustrates the use of the WriteImage method in copying a controller image from one controller to another.
Dim image() As Integer
' Create a new RMCLink object for the first controller.
Dim rmc As RMCLink = RMCLink.CreateUSBLink(DeviceType.RMC70, "7573091001")
' Read the image into our variable.
image = rmc.ReadImage(0)
' Create a new RMCLink object for the second controller.
Dim rmc2 As RMCLink = RMCLink.CreateUSBLink(DeviceType.RMC70, "7573091002")
rmc2.Connect()
' Apply the image to the second controller.
rmc2.WriteImage(0, image)
rmc2.Disconnect()
int[] image;
RMCLink rmc = RMCLink.CreateUSBLink(DeviceType.RMC70, "7573091001");
// Read the image into our variable.
image = rmc.ReadImage(0);
// Create a new RMCLink object for the second controller.
RMCLink rmc2 = RMCLink.CreateUSBLink(DeviceType.RMC70, "7573091002");
rmc2.Connect();
// Apply the image to the second controller.
rmc2.WriteImage(0, image);
rmc2.Disconnect();
array <int>^ image;
RMCLink^ rmc = RMCLink::CreateUSBLink(DeviceType::RMC70, "7573091001");
image = rmc->ReadImage(0);
RMCLink^ rmc2 = RMCLink::CreateUSBLink(DeviceType::RMC70, "7573091002");
rmc2->Connect();
rmc2->WriteImage(0, image);
rmc2->Disconnect();
RMCLink.Interop .NET Assembly | RMCLinkNET Namespace | RMCLink Class | ReadImage| ReadImageToFile | WriteImageFromFile
