RMCLink.Interop .NET Assembly RMCLink.Disconnect Method |
Closes the connection, if one has been established, associated with this RMCLink object.
Public Sub Disconnect |
Dim instance As RMCLink
instance.Disconnect() |
public void Disconnect () |
public: void Disconnect () |
On serial connections, the serial port will be released for use by other applications. On Ethernet connection, the TCP/IP connection will be closed.
This method is synchronous, which means that it will not return until the link is disconnected. However, disconnecting generally takes only a fraction of a second.
WARNING: For Ethernet connections, it is highly recommended that the connection not be disconnected and re-connected between transactions. Doing so will have lower performance, and more importantly, each call to Connect() will consume a TCP connection in the Windows operating system. This TCP connection will not be fully released by the operating system until typically 2 minutes after Disconnect() is called. Therefore, it is possible to consume all available TCP connections by repeated calls to Connect()/Disconnect() and as a result be unable to re-connect over RMCLink or even adversely affect other applications running on the same PC.
Exception Type |
Condition |
This link was already disconnected. |
The following code example illustrates the use of the Disconnect method.
' Read and display Axis 0's Actual Position (F8:8).
rmc.ReadFFile(FileNumber70.fn70StatusAxis0,8,data,0,1)
Console.WriteLine("Axis0 Actual Position = " & data(0) & " inches")
// Create the object itself.
// Read and display Axis 0's Actual Position.
float[] data = new float[1];
rmc.ReadFFile(FileNumber70.fn70StatusAxis0,8,data,0,1);
Console.WriteLine("Axis0 Actual Position = " + data[0] + " inches");
rmc->ReadFFile(FileNumber70::fn70StatusAxis0,8,data,0,1);
Console::WriteLine("Axis0 Actual Position = " + data[0] + " inches");
