RMCLink.Interop .NET Assembly RMCLink.WriteImageFromFile Method |
Loads the controller image from the specified file, writes it to the controller and applies it. By default, the image will be saved to flash and the controller will be restarted. The controller image file must have been created using the ReadImageToFile method. For saving and restoring the controller image using an array in memory instead of using a file, use the ReadImage and WriteImage methods. This method is only supported on the RMC75E, RMC150E, and RMC200 controllers.
Public Sub WriteImageFromFile ( _ flags As Integer _ ) |
Dim instance As RMCLink Dim flags As Integer Dim fileName As String
instance.WriteImageFromFile(flags, fileName) |
public void WriteImageFromFile ( int flags, string fileName ) |
public: void WriteImageFromFile ( int flags String^ fileName ) |
flags
Options to use when applying the image. Refer to the RMCTools documentation on the Image Area for a current list of options. As of this writing, a single option has been defined. Specify zero (0) to use default options.
+0 |
Save Image to Flash, and Restart Controller to Apply |
+16 |
Apply Image Immediately and Save To Flash (not supported by RMC200) |
fileName
File name and path to load the controller image from.
Exception Type |
Condition |
The fileName parameter refers to a null (Nothing in Visual Basic) object. |
The flags parameter is out of range, or the fileName parameter is blank. |
One of the following circumstances occurred:
The read failed due to a communication failure. Check that the remote device is powered up, check the communication wiring, and check the communication configuration of both the local and remote devices. Check the Message property of the exception for a description of the communication failure. |
System.IO.PathTooLongException
The specified path, file name, or both exceed the system-defined maximum length. For example, on Windows-based platforms, paths must be less than 248 characters, and file names must be less than 260 characters. |
The specified path is invalid, (for example, it is on an unmapped drive). |
fileName specified a directory -or- The caller does not have the required permission. |
The file specified in fileName was not found. |
fileName is in an invalid format. |
The end of the stream was reached unexpectedly. |
An I/O error occurred while creating or writing to the file. |
The following code example illustrates the use of the WriteImageFromFile method.
Dim image() As Integer
' Create a new RMCLink object for the first controller.
Dim rmc As RMCLink = RMCLink.CreateEthernetLink(DeviceType.RMC70, "192.168.0.22")
' Load the image from 'RMCImage.bin' and apply it to the controller.
rmc.WriteImageFromFile(0, "RMCImage.bin")
int[] image;
RMCLink rmc = RMCLink.CreateEthernetLink(DeviceType.RMC70, "192.168.0.22");
// Load the image from 'RMCImage.bin' and apply it to the controller.
rmc.WriteImageFromFile(0, "RMCImage.bin");
array <int>^ image;
RMCLink^ rmc = RMCLink::CreateEthernetLink(DeviceType::RMC70, "192.168.0.22");
rmc->WriteImageFromFile(0, "RMCImage.bin");
RMCLink.Interop .NET Assembly | RMCLinkNET Namespace | RMCLink Class | ReadImageToFile | ReadImage| WriteImage
