RMCLink.Interop .NET Assembly RMCLink.ReadImage Method |
Reads the entire controller image into an integer array. This image can be applied to another controller of the same physical configuration using the WriteImage method. For saving and restoring the controller image using a file, use the ReadImageToFile and WriteImageFromFile methods. This method is only supported on the RMC75E, RMC150E, and RMC200 controllers.
Public Function ReadImage ( _ flags As Integer _ ) As Integer() |
Dim instance As RMCLink Dim flags As Integer Dim returnValue() As Integer
returnValue = instance.ReadImage(flags) |
public int[] ReadImage ( int flags ) |
public: array<int>^ ReadImage ( int flags ) |
flags
Options to use when building the controller image. Refer to the RMCTools documentation on the Image Area for a current list of options. As of this writing no options have been defined. Specify zero (0) to use default options.
The array of Integer elements will contain the image read from the controller. The length of this array will vary depending on the actual contents of the controller.
Exception Type |
Condition |
ArgumentOutOfRangeException |
The flags parameter is out of range. |
InvalidOperationException |
One of the following circumstances occurred:
Check the Message property of the exception for a description of the exception. |
The read failed due to a communication failure. Check that the remote device is powered up, check the communication wiring, and check the communication configuration of both the local and remote devices. Check the Message property of the exception for a description of the communication failure. |
The following code example illustrates the use of the ReadImage method in copying a controller image from one controller to another.
Dim image() As Integer
' Create a new RMCLink object for the first controller.
Dim rmc As RMCLink = RMCLink.CreateUSBLink(DeviceType.RMC70, "7573091001")
' Read the image into our variable.
image = rmc.ReadImage(0)
' Create a new RMCLink object for the second controller.
Dim rmc2 As RMCLink = RMCLink.CreateUSBLink(DeviceType.RMC70, "7573091002")
rmc2.Connect()
' Apply the image to the second controller.
rmc2.WriteImage(0, image)
rmc2.Disconnect()
int[] image;
RMCLink rmc = RMCLink.CreateUSBLink(DeviceType.RMC70, "7573091001");
// Read the image into our variable.
image = rmc.ReadImage(0);
// Create a new RMCLink object for the second controller.
RMCLink rmc2 = RMCLink.CreateUSBLink(DeviceType.RMC70, "7573091002");
rmc2.Connect();
// Apply the image to the second controller.
rmc2.WriteImage(0, image);
rmc2.Disconnect();
array<int>^ image;
RMCLink^ rmc = RMCLink::CreateUSBLink(DeviceType::RMC70, "7573091001");
image = rmc->ReadImage(0);
RMCLink^ rmc2 = RMCLink::CreateUSBLink(DeviceType::RMC70, "7573091002");
rmc2->Connect();
rmc2->WriteImage(0, image);
rmc2->Disconnect();
RMCLink.Interop .NET Assembly | RMCLinkNET Namespace | RMCLink Class | WriteImage | ReadImageToFile | WriteImageFromFile
