RMCLink.Interop .NET Assembly RMCLink.WriteLFile Method |
Writes to one or more integer (L) registers in the controller. Since all RMC100 registers are integer registers, this function should be used for all writes to RMC100 controllers. It should also be used when writing integer values to RMC70, RMC150, or RMC200 registers. Compare with WriteFFile.
Public Sub WriteLFile ( _ file As Integer, _ element As Integer, _ data() As Integer, _ offsetAs Integer, _ count As Integer _ ) |
Dim instance As RMCLink Dim file As Integer Dim element As Integer Dim data() as Integer Dim offset As Integer Dim count As Integer
instance.WriteLFile(file, element, data, offset, count) |
public void WriteLFile ( int file, int element, int[] data, int offset, int count ) |
public: void WriteLFile ( int file, int element, array<int>^ data, int offset, int count ) |
File number of the first register to write to. See the RMCLink Register Reference for details.
Element number of the first register to write to. See the RMCLink Register Reference for details.
data
The array of System.Int32 that holds the data to be written to the controller. Notice that the offset and count parameters control which portion of the array will be written.
offset
The element number in the source data array of the first write value. This offset only applies to the source array and will not affect the write location.
count
The number of registers to written from the data array into the controller.
Exception Type |
Condition |
Either the data being written to is read-only, or the write overflows the maximum file size of 65536 elements. The sum of offset and count must be less than or equal to 65536. |
The data parameter refers to a null (Nothing in Visual Basic) object. |
One of the file and element parameters is out of range. Ensure that file and element are between 0 and 65535. |
This write was cancelled by a call on another thread to one of the Disconnect and CancelRequest methods. |
The link is not currently connected. The Connect method must be called before attempting to write to the controller. |
The write failed due to a communication failure. Check that the remote device is powered up, check the communication wiring, and check the communication configuration of both the local and remote devices. Check the Message property of the exception for a description of the communication failure. |
The following code example illustrates the use of the WriteLFile method.
Dim rmc As RMCLink = RMCLink.CreateEthernetLink(DeviceType.RMC100, "192.168.0.10")
' Issue a Go (G) command to axis 0.
Dim cmd() As Integer = new Integer(5) {}
cmd(0) = &H81 ' Mode (S-Curves, Accel/Decel in pu/s/s)
cmd(1) = 100 ' Accel
cmd(2) = 100 ' Decel
cmd(3) = 1000 ' Speed
cmd(4) = 10000 ' Req. Position (10.000 inches)
cmd(5) = Asc("G") ' Command (Go)
rmc.WriteLFile(FileNumber100.fn100CommandAxis0,0,cmd,0,6);
// Create the object itself.
RMCLink rmc = RMCLink.CreateEthernetLink(DeviceType.RMC100, "192.168.0.10");
// Issue a Go (G) command to axis 0.
int[] cmd = new int[6];
cmd[0] = 0x0081; // Mode (S-Curves, Accel/Decel in pu/s/s)
cmd[1] = 100; // Accel
cmd[2] = 100; // Decel
cmd[3] = 1000; // Speed
cmd[4] = 10000; // Req. Position (10.000 inches)
cmd[5] = (int)'G'; // Command
array<int>^ cmd = gcnew array<int>(6);
rmc->WriteLFile(FileNumber100.fn100CommandAxis0,0,cmd,0,6);
RMCLink.Interop .NET Assembly | RMCLinkNET Namespace | RMCLink Class | WriteFFile
