RMCLink.Interop .NET Assembly RMCLink.ReadLFile Method |
Reads one or more integer (L) registers from the controller. ReadLFile is typically used to read RMC100 registers (which are all integer registers), or to read RMC70, RMC150, or RMC200 registers in integer format. Compare with ReadFFile.
Public Sub ReadLFile ( _ file As Integer, _ element As Integer, _ data() As Integer, _ offsetAs Integer, _ count As Integer _ ) |
Dim instance As RMCLink Dim file As Integer Dim element As Integer Dim data() as Integer Dim offset As Integer Dim count As Integer
instance.ReadLFile(file, element, data, offset, count) |
public void ReadLFile ( int file, int element, int[] data, int offset, int count ) |
public: void ReadLFile ( int file, int element, array<int>^ data, int offset, int count ) |
data
The array of System.Int32 into which the read data is to be placed. The offset and count parameters determine the actual location in the array.
offset
The element number in the destination data array where the first read value will be placed. This offset only applies to the destination array and will not affect the read location.
count
The number of registers to read and placed in data.
Exception Type |
Condition |
The read overflows the maximum file size of 65536 elements. The sum of offset and count must be less than or equal to 65536. |
The data parameter refers to a null (Nothing in Visual Basic) object. |
One of the file and element parameters is out of range. Ensure that file and element are between 0 and 65535. |
The link is not currently connected. The Connect method must be called before attempting to read from the controller. |
The read failed due to a communication failure. Check that the remote device is powered up, check the communication wiring, and check the communication configuration of both the local and remote devices. Check the Message property of the exception for a description of the communication failure. |
The following code example illustrates the use of the ReadLFile method.
Dim rmc As RMCLink = RMCLink.CreateSerialLink(DeviceType.RMC100, "COM1")
' Read and display Axis 0's Command, Target, and Actual Positions (L0:0-2).
Dim data() As Integer = New Integer(2) {}
rmc.ReadLFile(FileNumber100.fn100StatusAxis0,0,data,0,3)
Console.WriteLine("Axis 0:")
Console.WriteLine(" Command Position: " & data(0) & " inches")
Console.WriteLine(" Target Position: " & data(1) & " inches")
Console.WriteLine(" Actual Position: " & data(2) & " inches")
// Create the object itself.
RMCLink rmc = RMCLink.CreateSerialLink(DeviceType.RMC100, "COM1");
// Read and display Axis 0's Command, Target, and Actual Positions (L0:0-2).
float[] data = new float[3];
rmc.ReadLFile(FileNumber100.fn100StatusAxis0,0,data,0,3);
Console.WriteLine("Axis 0:");
Console.WriteLine(" Command Position: " + data[0] + " inches");
Console.WriteLine(" Target Position: " + data[1] + " inches");
Console.WriteLine(" Actual Position: " + data[2] + " inches");
RMCLink^ rmc = RMCLink::CreateSerialLink(DeviceType::RMC100, "COM1");
array<float>^ data = gcnew array<float>(3);
rmc->ReadLFile(FileNumber100::fn100StatusAxis0,0,data,0,3);
Console::WriteLine("Axis 0:");
Console::WriteLine(" Command Position: " + data[0] + " inches");
Console::WriteLine(" Target Position: " + data[1] + " inches");
Console::WriteLine(" Actual Position: " + data[2] + " inches");
RMCLink.Interop .NET Assembly | RMCLinkNET Namespace | RMCLink Class | ReadFFile
