RMCLink.Interop .NET Assembly RMCLink.ReadBit Method |
Reads a single bit from an integer (L) register in the RMC. ReadBit is typically used to read the value of a status bit in the RMC.
Public Function ReadBit ( _ file As Integer, _ element As Integer, _ bit As Integer _ ) As Boolean |
Dim instance As RMCLink Dim file As Integer Dim element As Integer Dim bit As Integer Dim returnValue As Boolean
returnValue = instance.ReadBit(file, element, bit) |
public bool ReadBit ( int file, int element, int bit ) |
public: bool ReadBit ( int file, int element, int bit ) |
File number of the register with the bit to be read. See the RMCLink Register Reference for details.
Element number of the register with the bit to be read. See the RMCLink Register Reference for details.
bit
Number of the bit (0-31) to read in the register. Bits are numbered from least to most significant.
If the bit that was read was 1, then true (True in Visual Basic) is returned, otherwise false (False in Visual Basic) is returned.
Exception Type |
Condition |
One of the file, element, and bit parameters is out of range. Ensure that file and element are between 0 and 65535, and that bit is between 0 and 31. |
The link is not currently connected. The Connect method must be called before attempting to read from the controller. |
The read failed due to a communication failure. Check that the remote device is powered up, check the communication wiring, and check the communication configuration of both the local and remote devices. Check the Message property of the exception for a description of the communication failure. |
The following code example illustrates the use of the ReadBit method.
' Read and display Axis 0's In Position Bit (L8:0/0).
Dim inPosition As Boolean = rmc.ReadBit(FileNumber70.fn70StatusAxis0,0,0)
Console.WriteLine("Axis0 In Position? " & inPosition)
// Create the object itself.
// Read and display Axis 0's In Position Bit (L8:0/0).
bool inPosition = rmc.ReadBit(FileNumber70.fn70StatusAxis0,0,0);
Console.WriteLine("Axis0 In Position? " + inPosition);
bool inPosition = rmc->ReadBit(FileNumber70::fn70StatusAxis0,0,0);
Console::WriteLine("Axis0 In Position? " + inPosition);
