RMCLink C++ Wrapper Class CRMCLink::WriteImage Method |
Writes the specified controller image to the controller and applies it to the controller. By default, the image will be saved to flash and the controller will be restarted. The controller image must be obtained using the ReadImage method. For saving and restoring the controller image using a file, use the ReadImageToFile and WriteImageFromFile methods. This method is only supported on the RMC75E, RMC150E, and RMC200 controllers.
HRESULT WriteImage( UINT flags, long const* data, UINT count ); |
flags
Options to use when applying the image. Refer to the RMCTools documentation on the Image Area for a current list of options. As of this writing, a single option has been defined. Specify zero (0) to use default options.
+0 |
Save Image to Flash, and Restart Controller to Apply |
+16 |
Apply Image Immediately and Save To Flash (not supported by RMC200) |
data
A pointer to the array of long values containing the controller image. This data must have been created using the ReadImage method.
count
The length (in long elements) of the array passed into the data parameter.
E_OUTOFMEMORY |
E_INVALIDARG |
RMCLINK_E_DISCONNECTING |
RMCLINK_E_DISCONNECTED |
RMCLINK_E_SOCK_INTERNAL |
RMCLINK_E_CANCELLED |
RMCLINK_E_TIMEOUT |
RMCLINK_E_SOCK_ERROR_RD |
RMCLINK_E_SOCK_INV_RD_LEN |
RMCLINK_E_SOCK_ERROR_WR |
RMCLINK_E_SOCK_INV_WR_LEN |
RMCLINK_E_CONN_BROKEN |
RMCLINK_E_PARTIAL_WRITE |
RMCLINK_E_USB_SETTIMEOUT |
RMCLINK_E_USB_OP_ABORT |
RMCLINK_E_USB_DISCONNECT |
RMCLINK_E_NOT_SUPPORTED |
RMCLINK_E_DL_CANT_RESET |
Unable to reset Image Area for download. |
RMCLINK_E_DL_FAILED |
Unable to download controller image. |
RMCLINK_E_BAD_IMAGE |
Image format is invalid. |
RMCLINK_E_APPLY_TIMEOUT |
RMCLINK_E_APPLY_STATE |
Unexpected state encountered while applying image. |
RMCLINK_E_APPLY_RSTREQ |
Image not applied because restart required. |
RMCLINK_E_APPLY_FLASH |
Error writing to flash memory while applying image. |
RMCLINK_E_APPLY_NOTINRUN |
Image cannot be applied without restart while in RUN mode. |
RMCLINK_E_APPLY_WRONGHW |
Image not applied because of hardware mismatch. |
The following code example illustrates the use of the WriteImage method.
long* palData = NULL;
UINT uDataLen = 0;
CRMCLink* pRMC = CRMCLink::CreateUSBLink(CRMCLink::dtRMC70, _T("7573091001"));
hr = pRMC->ReadImage(0, palData, uDataLen);
if ( palData != NULL )
// Create a new RMCLink object for the second controller.
CRMCLink* pRMC2 = CRMCLink::CreateUSBLink(CRMCLink::dtRMC70, _T("7573091002"));
if ( pRMC2 != NULL )
HRESULT hr = pRMC2->Connect();
// Apply the image to the same controller.
hr = pRMC2->WriteImage(0, palData, uDataLen);
printf("Successfully copied controller image.");
pRMC2->Disconnect();
delete pRMC2;
// Free the data allocated by ReadImage().
delete[] palData;
CRMCLink Class | RMCLink C++ Wrapper Class | CRMCLink::ReadImage | CRMCLink::ReadImageToFile Method | CRMCLink::WriteImageFromFile
