RMCLink C++ Wrapper Class CRMCLink::WriteImageFromFile Method |
Loads the controller image from the specified file, writes it to the controller and applies it. By default, the image will be saved to flash and the controller will be restarted. The controller image file must have been created using the ReadImageToFile method. For saving and restoring the controller image using an array in memory instead of using a file, use the ReadImage and WriteImage methods. This method is only supported on the RMC75E, RMC150E, and RMC200 controllers.
HRESULT WriteImageFromFile( UINT flags, LPCTSTR fileName ); |
flags
Options to use when applying the image. Refer to the RMCTools documentation on the Image Area for a current list of options. As of this writing, a single option has been defined. Specify zero (0) to use default options.
+0 |
Save Image to Flash, and Restart Controller to Apply |
+16 |
Apply Image Immediately and Save To Flash (not supported by RMC200) |
fileName
File name and path to load the controller image from.
E_OUTOFMEMORY |
E_INVALIDARG |
RMCLINK_E_DISCONNECTING |
RMCLINK_E_DISCONNECTED |
RMCLINK_E_SOCK_INTERNAL |
RMCLINK_E_CANCELLED |
RMCLINK_E_TIMEOUT |
RMCLINK_E_SOCK_ERROR_RD |
RMCLINK_E_SOCK_INV_RD_LEN |
RMCLINK_E_SOCK_ERROR_WR |
RMCLINK_E_SOCK_INV_WR_LEN |
RMCLINK_E_CONN_BROKEN |
RMCLINK_E_PARTIAL_WRITE |
RMCLINK_E_USB_SETTIMEOUT |
RMCLINK_E_USB_OP_ABORT |
RMCLINK_E_USB_DISCONNECT |
RMCLINK_E_NOT_SUPPORTED |
RMCLINK_E_DL_CANT_RESET |
Unable to reset Image Area for download. |
RMCLINK_E_DL_FAILED |
Unable to download controller image. |
RMCLINK_E_BAD_IMAGE |
Image format is invalid. |
RMCLINK_E_APPLY_TIMEOUT |
RMCLINK_E_APPLY_STATE |
Unexpected state encountered while applying image. |
RMCLINK_E_APPLY_RSTREQ |
Image not applied because restart required. |
RMCLINK_E_APPLY_FLASH |
Error writing to flash memory while applying image. |
RMCLINK_E_APPLY_NOTINRUN |
Image cannot be applied without restart while in RUN mode. |
RMCLINK_E_APPLY_WRONGHW |
Image not applied because of hardware mismatch. |
RMCLINK_E_FILE_NOT_FOUND |
Unable the find the specified file. |
RMCLINK_E_PATH_NOT_FOUND |
Unable the find the specified file path. Check that the drive and folder specified exist. |
RMCLINK_E_ACCESS_DENIED |
Access denied to the file or path. Verify that the file is not opened by another application and that you have access to the folder and file. |
RMCLINK_E_DRIVE_NOT_READY |
Removable drive not ready. Verify that media has been inserted into the removable drive. |
The following code example illustrates the use of the WriteImageFromFile method.
CRMCLink* pRMC = CRMCLink::CreateUSBLink(CRMCLink::dtRMC70, _T("7573091001"));
hr = pRMC->WriteImageFromFile(0, _T("RMCImage.bin"));
printf("Successfully applied controller image.");
} // Close the connection.
} // Release the COM sub-system.
CRMCLink Class | RMCLink C++ Wrapper Class | CRMCLink::ReadImageToFile Method | CRMCLink::ReadImage | CRMCLink::WriteImage
