RMCLink C++ Wrapper Class CRMCLink::ReadImage Method |
Reads the entire controller image into an integer array. This image can be applied to another controller of the same physical configuration using the WriteImage method. For saving and restoring the controller image using a file, use the ReadImageToFile and WriteImageFromFile methods. This method is only supported on the RMC75E, RMC150E, and RMC200 controllers.
HRESULT ReadImage( UINT flags, long*& data, UINT& count ); |
flags
Options to use when building the controller image. Refer to the RMCTools documentation on the Image Area for a current list of options. As of this writing no options have been defined. Specify zero (0) to use default options.
data
An array of long values will be allocated by this method, and a pointer to this array will be returned in this parameter. Use delete[] to free this array when done using it.
count
The length (in long elements) of the array returned in the data parameter will be returned in this parameter.
E_OUTOFMEMORY |
E_INVALIDARG |
RMCLINK_E_DISCONNECTING |
RMCLINK_E_DISCONNECTED |
RMCLINK_E_SOCK_INTERNAL |
RMCLINK_E_CANCELLED |
RMCLINK_E_TIMEOUT |
RMCLINK_E_SOCK_ERROR_RD |
RMCLINK_E_SOCK_INV_RD_LEN |
RMCLINK_E_SOCK_ERROR_WR |
RMCLINK_E_SOCK_INV_WR_LEN |
RMCLINK_E_CONN_BROKEN |
RMCLINK_E_PARTIAL_WRITE |
RMCLINK_E_USB_SETTIMEOUT |
RMCLINK_E_USB_OP_ABORT |
RMCLINK_E_USB_DISCONNECT |
RMCLINK_E_NOT_SUPPORTED |
RMCLINK_E_BLDIMG_TIMEOUT |
Timeout waiting for image to be built. |
RMCLINK_E_BLDIMG_ERROR |
Controller unable to build image. |
RMCLINK_E_BLDIMG_STATE |
Unexpected state encountered while building image. |
RMCLINK_E_BLDIMG_NOT_ALLOWED |
Controller unable to build upload image because copy protection is enabled. |
RMCLINK_E_UL_FAILED |
Unable to upload completed image. |
The following code example illustrates the use of the ReadImage method.
long* palData = NULL;
UINT uDataLen = 0;
CRMCLink* pRMC = CRMCLink::CreateUSBLink(CRMCLink::dtRMC70, _T("7573091001"));
hr = pRMC->ReadImage(0, palData, uDataLen);
if ( palData != NULL )
// Create a new RMCLink object for the second controller.
CRMCLink* pRMC2 = CRMCLink::CreateUSBLink(CRMCLink::dtRMC70, _T("7573091002"));
if ( pRMC2 != NULL )
HRESULT hr = pRMC2->Connect();
// Apply the image to the same controller.
hr = pRMC2->WriteImage(0, palData, uDataLen);
printf("Successfully copied controller image.");
pRMC2->Disconnect();
delete pRMC2;
// Free the data allocated by ReadImage().
delete[] palData;
CRMCLink Class | RMCLink C++ Wrapper Class | CRMCLink::WriteImage | CRMCLink::ReadImageToFile Method | CRMCLink::WriteImageFromFile Method
