RMCLink C++ Wrapper Class CRMCLink::ReadImageToFile Method |
Reads the entire controller image and saves it to a file. This file can then be written and applied to another controller of the same physical configuration using the WriteImageFromFile method. For saving and restoring the controller image using an array rather than a file, use the ReadImage and WriteImage methods. This method is only supported on the RMC75E, RMC150E, and RMC200 controllers.
HRESULT ReadImageToFile( UINT flags, LPCTSTR fileName ); |
flags
Options to use when building the controller image. Refer to the RMCTools documentation on the Image Area for a current list of options. As of this writing no options have been defined. Specify zero (0) to use default options.
fileName
File name and path to save the controller image into.
E_OUTOFMEMORY |
E_INVALIDARG |
RMCLINK_E_DISCONNECTING |
RMCLINK_E_DISCONNECTED |
RMCLINK_E_SOCK_INTERNAL |
RMCLINK_E_CANCELLED |
RMCLINK_E_TIMEOUT |
RMCLINK_E_SOCK_ERROR_RD |
RMCLINK_E_SOCK_INV_RD_LEN |
RMCLINK_E_SOCK_ERROR_WR |
RMCLINK_E_SOCK_INV_WR_LEN |
RMCLINK_E_CONN_BROKEN |
RMCLINK_E_PARTIAL_WRITE |
RMCLINK_E_USB_SETTIMEOUT |
RMCLINK_E_USB_OP_ABORT |
RMCLINK_E_USB_DISCONNECT |
RMCLINK_E_NOT_SUPPORTED |
RMCLINK_E_BLDIMG_TIMEOUT |
Timeout waiting for image to be built. |
RMCLINK_E_BLDIMG_ERROR |
Controller unable to build image. |
RMCLINK_E_BLDIMG_STATE |
Unexpected state encountered while building image. |
RMCLINK_E_BLDIMG_NOT_ALLOWED |
Controller unable to build upload image because copy protection is enabled. |
RMCLINK_E_UL_FAILED |
Unable to upload completed image. |
RMCLINK_E_PATH_NOT_FOUND |
Unable the find the specified file path. Check that the drive and folder specified exist. |
RMCLINK_E_ACCESS_DENIED |
Access denied to the file or path. Verify that you have access to create files in the specified folder, or if you are saving over an existing file, make sure that the existing file is not read-only or currently open by another application. |
RMCLINK_E_DRIVE_NOT_READY |
Removable drive not ready. Verify that media has been inserted into the removable drive. |
The following code example illustrates the use of the ReadImageToFile method.
hr = pRMC->ReadImageToFile(0, _T("RMCImage.bin"));
printf("Successfully saved controller image in RMCImage.bin!");
CRMCLink Class | RMCLink C++ Wrapper Class | CRMCLink::WriteImageFromFile | CRMCLink::ReadImage | CRMCLink::WriteImage
