RMCLink COM Component RMCLink.WriteImage Method |
Writes the specified controller image to the controller and applies it to the controller. By default, the image will be saved to flash and the controller will be restarted. The controller image must be obtained using the ReadImage method. For saving and restoring the controller image using a file, use the ReadImageToFile and WriteImageFromFile methods. This method is only supported on the RMC75E, RMC150E, and RMC200 controllers.
Sub WriteImage ( _ flags As Long, _ data As Variant _ ) |
Dim instance As RMCLink Dim flags As Long Dim data As Variant
instance.WriteImageflags, data |
flags
Options to use when applying the image. Refer to the RMCTools documentation on the Image Area for a current list of options. As of this writing, a single option has been defined. Specify zero (0) to use default options.
+0 |
Save Image to Flash, and Restart Controller to Apply |
+16 |
Apply Image Immediately and Save To Flash (not supported by RMC200) |
data
This variant must be a single-dimension array of Long data type elements that was created using the ReadImage method.
Error Code |
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
rmcEDisconnecting = 1002 |
rmcEDisconnected = 1005 |
rmcESocketInternal = 1008 |
rmcECancelled = 1010 |
rmcETimeout = 1011 |
rmcESocketReadError = 1015 |
rmcESocketInvReadLen = 1016 |
rmcESocketWriteError = 1017 |
rmcEConnectionBroken = 1028 |
rmcEPartialWrite = 1029 |
rmcEBadAddress = 1032 |
rmcENotSupported = 1035 |
rmcEImageResetFailed = 1040 |
Unable to reset Image Area for download. |
rmcEImageDownloadFailed = 1041 |
Unable to download controller image. |
rmcEImageInvalid = 1042 |
Timeout applying downloaded image. |
rmcEImageApplyTimeout = 1043 |
Image format is invalid. |
rmcEImageApplyState = 1044 |
Unexpected state encountered while applying image. |
rmcEImageApplyResetReq = 1045 |
Image not applied because restart required. |
rmcEImageApplyFlashError = 1046 |
Error writing to flash memory while applying image. |
rmcEImageApplyRunMode = 1047 |
Image cannot be applied without restart while in RUN mode. |
rmcEImageApplyHWMismatch = 1048 |
Image not applied because of hardware mismatch. |
rmcEUSBInternal1 = 1051 |
rmcEUSBDisconnected = 1054 |
The following code example illustrates the use of the WriteImage method in copying a controller image from one controller to another.
Dim image As Variant
' Create a new RMCLink object for the first controller.
Set rmc = srv.CreateUSBLink(dtRMC70, "7573091001")
' Read the image into our variable.
image = rmc.ReadImage(0)
' Create a new RMCLink object for the second controller.
Dim rmc2 As RMCLink
Set rmc2 = srv.CreateUSBLink(dtRMC70, "7573091002")
rmc2.Connect
rmc2.WriteImage 0, image
rmc2.Disconnect
Dim srv, rmc, rmc2, image
Set rmc = srv.CreateUSBLink(2, "7573091001")
Set rmc2 = srv.CreateUSBLink(2, "7573091002")
rmc2.Connect
rmc2.Disconnect
var rmc = srv.CreateUSBLink(2, "7573091001");// Connect to the controller.
// Read the image into our variable.
var image = rmc.ReadImage(0);
// Create a new RMCLink object for the second controller.
var rmc2 = srv.CreateUSBLink(2, "7573091002");
rmc2.Connect();
rmc2.WriteImage(0, image);
rmc2.Disconnect();
RMCLinkServer Class | RMCLink Class | RMCLink COM Component | ReadImage | ReadImageToFile | WriteImageFromFile
