RMCLink COM Component RMCLink.ReadImage Method |
Reads the entire controller image into an integer array. This image can be applied to another controller of the same physical configuration using the WriteImage method. For saving and restoring the controller image using a file, use the ReadImageToFile and WriteImageFromFile methods. This method is only supported on the RMC75E, RMC150E, and RMC200 controllers.
Function ReadImage ( _ flags As Long _ ) As Variant |
Dim instance As RMCLink Dim flags As Long Dim returnValue As Variant
returnValue = instance.ReadImage(flags) |
flags
Options to use when building the controller image. Refer to the RMCTools documentation on the Image Area for a current list of options. As of this writing no options have been defined. Specify zero (0) to use default options.
This variant will contain the controller image read from the controller. The data type will be a single-dimension 0-based array of Long elements. The length of this array will vary depending on the actual contents of the controller.
Error Code |
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
rmcEDisconnecting = 1002 |
rmcEDisconnected = 1005 |
rmcESocketInternal = 1008 |
rmcECancelled = 1010 |
rmcETimeout = 1011 |
rmcESocketReadError = 1015 |
rmcESocketInvReadLen = 1016 |
rmcESocketWriteError = 1017 |
rmcEConnectionBroken = 1028 |
rmcEPartialWrite = 1029 |
rmcEBadAddress = 1032 |
rmcENotSupported = 1035 |
rmcEBuildImgTimeout = 1036 |
Timeout waiting for image to be built. |
rmcEBuildImgError = 1037 |
Controller unable to build image. |
rmcEBuildImgState = 1038 |
Unexpected state encountered while building image. |
rmcEImageUploadFailed = 1039 |
Unable to upload completed image. |
rmcEUSBInternal1 = 1051 |
rmcEUSBDisconnected = 1054 |
rmcEBuildImgNotAllowed = 1062 |
Controller unable to build upload image because copy protection is enabled. |
The following code example illustrates the use of the ReadImage method in copying a controller image from one controller to another.
Dim image As Variant
' Create a new RMCLink object for the first controller.
Set rmc = srv.CreateUSBLink(dtRMC70, "7573091001")
' Read the image into our variable.
image = rmc.ReadImage(0)
' Create a new RMCLink object for the second controller.
Dim rmc2 As RMCLink
Set rmc2 = srv.CreateUSBLink(dtRMC70, "7573091002")
rmc2.Connect
rmc2.WriteImage 0, image
rmc2.Disconnect
Dim srv, rmc, rmc2, image
Set rmc = srv.CreateUSBLink(2, "7573091001")
Set rmc2 = srv.CreateUSBLink(2, "7573091002")
rmc2.Connect
rmc2.Disconnect
var rmc = srv.CreateUSBLink(2, "7573091001");
// Read the image into our variable.
var image = rmc.ReadImage(0);
// Create a new RMCLink object for the second controller.
var rmc2 = srv.CreateUSBLink(2, "7573091002");
rmc2.Connect();
rmc2.WriteImage(0, image);
rmc2.Disconnect();
RMCLinkServer Class | RMCLink Class | RMCLink COM Component | WriteImage| ReadImageToFile | WriteImageFromFile
