RMCLink COM Component RMCLink.ReadImageToFile Method |
Reads the entire controller image and saves it to a file. This file can then be written and applied to another controller of the same physical configuration using the WriteImageFromFile method. For saving and restoring the controller image using an array rather than a file, use the ReadImage and WriteImage methods. This method is only supported on the RMC75E, RMC150E, and RMC200 controllers with firmware 3.34.0 or newer.
Sub ReadImageToFile ( _ flags As Long, _ fileName As String _ ) |
Dim instance As RMCLink Dim flags As Long Dim fileName As String
instance.ReadImageToFileflags, fileName |
flags
Options to use when building the controller image. Refer to the RMCTools documentation on the Image Area for a current list of options. As of this writing no options have been defined. Specify zero (0) to use default options.
fileName
File name and path to save the controller image into.
Error Code |
rmcEOutOfMemory = 5 |
rmcEInvalidArg = 7 |
rmcEDisconnecting = 1002 |
rmcEDisconnected = 1005 |
rmcESocketInternal = 1008 |
rmcECancelled = 1010 |
rmcETimeout = 1011 |
rmcESocketReadError = 1015 |
rmcESocketInvReadLen = 1016 |
rmcESocketWriteError = 1017 |
rmcEConnectionBroken = 1028 |
rmcEPartialWrite = 1029 |
rmcEBadAddress = 1032 |
rmcENotSupported = 1035 |
rmcEBuildImgTimeout = 1036 |
Timeout waiting for image to be built. |
rmcEBuildImgError = 1037 |
Controller unable to build image. |
rmcEBuildImgState = 1038 |
Unexpected state encountered while building image. |
rmcEImageUploadFailed = 1039 |
Unable to upload completed image. |
rmcEUSBInternal1 = 1051 |
rmcEUSBDisconnected = 1054 |
rmcEPathNotFound = 1059 |
Unable the find the specified file path. Check that the drive and folder specified exist. |
rmcEAccessDenied = 1060 |
Access denied to the file or path. Verify that you have access to create files in the specified folder, or if you are saving over an existing file, make sure that the existing file is not read-only or currently open by another application. |
rmcEDriveNotReady = 1061 |
Removable drive not ready. Verify that media has been inserted into the removable drive. |
rmcEBuildImgNotAllowed = 1062 |
Controller unable to build upload image because copy protection is enabled. |
The following code example illustrates the use of the ReadImageToFile method.
' Create a new RMCLink object for the controller.
' Read the image and save it to 'RMCImage.bin'.
rmc.ReadImageToFile 0, "RMCImage.bin"
Dim src, rmc
// Create a new RMCLink object for the controller.
// Read the image and save it to 'RMCImage.bin'.
rmc.ReadImageToFile(0, "RMCImage.bin");
RMCLinkServer Class | RMCLink Class | RMCLink COM Component | WriteImageFromFile | ReadImage | WriteImage
