Stepper Configuration
The RMC supports a wide range of quadrature encoders and homing configurations. The following settings should be set to match your system:
No jumpers are required for changing any of these settings. Instead, set the Configuration word and Maximum Steps Per Millisecond parameter for each axis used.
Defining the Encoder Error/Fault Input Status Bit
This status bit can represent either an encoder error or a fault error. Which of these two conditions gets reported in this status bit is configurable by the user. There are four options:
The use of this bit can be set only from RMCWin. Use the following steps:
  1. On the Tools menu, click Module Configuration.
  2. In the Slots list, click the Stepper module you want to edit.
  3. Click Slot options. The Quadrature with Stepper Output Options dialog box will be displayed with a tab for each axis on that slot.
  4. Click the Axis 0 tab.
  5. Check the conditions that you want to have set this status bit. You can check one, both, or neither condition.
  6. Click the Axis 1 tab.
  7. Check the conditions that you want to have set this status bit. You can check one, both, or neither condition.
  8. Click Update RMC.
  9. The Update Module Configuration dialog box will be displayed to indicate the progress. If the module could not be reset automatically, you may be prompted to reset the module yourself.
See also:
Stepper Overview
Stepper Wiring
Stepper LED Indicators
Stepper Specifications
Stepper Scaling
Stepper Compensation
Homing
