For quadrature axes, these bits are used to select the active states of four inputs and to define the use of the Home Input status bit in the Status word.
Fault Input Active State - Bit 15
This bit determines the active state of the Fault Input. The active state of this input indicates that a fault has occurred. The Encoder Error status bit is set when the Fault input is active.
Bit 15 |
Active Input State |
No current applied |
Current Applied |
Limit Inputs Active State - Bit 14
Determines the active state of the Extend (CW) and Retract (CCW) Limit Inputs. The active state of these inputs indicates that a limit has been reached. The Extend Limit status bit will be set when the Extend (CW) Limit Input is active, and the Retract Limit status bit will be set when the Retract (CCW) Limit Input is active:
Bit 14 |
Current applied |
Index (Z) Input Active State - Bit 13
Determines the active state of the Index (Z) Input:
Bit 13 |
Positive signal applied |
Negative signal applied |
Home (H) Input Active State - Bit 12
Determines the active state of the Home (H) Input:
Bit 12 |
Current applied |
Home Input Status Bit Level/Edge Select - Bit 7
This bit determines the use of the Home Input status bit, as shown below:
Bit 7 |
Home Input Status Bit Behavior |
Latched Home Edge The Home Input status bit is set and latched on the transition from both the index (Z) and home (H) inputs being active to one or both being inactive. |
Level of H Input |
For details on using this bit, see Homing a Quadrature Axis.
