Stepper Specifications
For general specifications on the RMC, see RMC100 Specifications.
Encoder
Axes
Two per module
Encoder Inputs
RS422 differential receiver
Quadrature A, B, and Index Z
ESD Protection
15 kV
Max. Encoder Frequency
4,000,000 counts/second
Index (Z) Response Time
63 nanoseconds
Inputs and Outputs
Fault Inputs, Home Inputs, and Limit Inputs
(Ext. & Ret.)
2.7 V @ 2.8 mA typical (3.2 V @ 3.5 mA max) threshold, 26.4 V maximum input voltage, 500 VDC isolation, compatible with most limit switches, TTL, and CMOS outputs
Drive Enable Output
(1 per axis)
Solid State relay, 50 W, 30 V, 100 mA
500 VDC isolation
Vcc Out
5 V ±20% @ 50 mA for use with Step, Direction, and Enable outputs. DO NOT power encoders with this output. See Stepper Wiring for details.
Motor Interface
Step and Direction Outputs
RS422 (5 V differential)
Pulse Width
50% duty cycle ± 80 nanoseconds
Max. Output Frequency
1 MHz
Direction Change Delays
Hold time = 16 us
Setup time = 112 us plus half step period
See also:
Stepper Overview
Stepper Wiring
Stepper Configuration
Stepper LED Indicators
Stepper Scaling
Stepper Compensation
Homing
