Set Parameter On-the-Fly
Character: None
Decimal: 208-223
Hexadecimal: 0xD0-0xDF
Command Value: Value of the Parameter
Note: This command is supported in RMC100 CPU firmware dated 19980414 or later.
Each of these commands sets one of the parameters. The following table can be used to determine which command sets which parameter. Reference axes parameters cannot be set on-the-fly. Notice that some parameters can never be set on the fly:
Command
MDT, SSI, Quad, Analog (Position)
Stepper
Pressure/force
Hex
Decimal
Parameter
Parameter
Parameter
0xD0
208
Config. Word
Invalid command
Invalid command
0xD1
209
Scale (2) (4)
Invalid command
Invalid command
0xD2
210
Offset (1)
Coordinate Limit (2)
Invalid command
0xD3
211
Extend Limit (1)
Extend Limit (2)
Invalid command
0xD4
212
Retract Limit (1)
Retract Limit (2)
Invalid command
0xD5
213
Proportional Gain
Compensation Rate (2)
Proportional Gain
0xD6
214
Integral Gain
Compensation Timeout (2)
Integral Gain
0xD7
215
Differential Gain
Invalid command
Differential Gain
0xD8
216
Extend Feed Fwd.
Steps/Rev (2)
Extend Feed Fwd
0xD9
217
Retract Feed Fwd.
Pos. Units/Rev (2)
Retract Feed Fwd
0xDA
218
Extend Acc. Feed Fwd.
Quad Counts/Rev (2)
Integrator Preload (3)
0xDB
219
Retract Acc. Feed Fwd.
Max. Steps/ms (2)
Filter Time Constant (3)
0xDC
220
Dead Band Eliminator
Compensation Window (2)
Invalid command
0xDD
221
In Position Window
In Position Window (2)
Invalid command
0xDE
222
Following Error Window
Following Error Window (2)
Invalid command
0xDF
223
Auto Stop Error Mask
Auto Stop Error Mask (2)
Invalid command
  1. Changing these parameters on-the-fly requires firmware 20000913 or later.
  2. Changing these parameters on-the-fly requires firmware 20001204 or later.
  3. Changing these parameters on-the-fly requires firmware 20020426 or later.
  4. Setting the scale on-the-fly requires that the axis be in open loop.
You will notice that some parameters cannot be changed on the fly. They can be changed by stopping the axis, writing the parameters, and issuing a Set Parameters command.
Warning: Changing any of the gains or feed forwards generates a drive discontinuity in most cases.
