Default: 0
Range: -65536 to 65535 (Quadrature), -65536 to 0 (Stepper)
This parameter is available only on stepper, resolver, and quadrature axes. It defines the 16-bit position unit range. For a complete discussion on the use of this parameter, read the topic that applies to the transducers you are using:
What if it is displayed under RMCWin incorrectly?
The Coordinate Limit parameter may be displayed incorrectly on the RMCWin main screen in some circumstances. The numbers are not necessarily incorrect (the module still functions correctly), but they may not look right. This is because RMCWin assumes the Coordinate Limit read from the RMC has a sign opposite of the scale for Quadrature (servo) axes until it is told otherwise. To correct the problem, enter the correct value for the Coordinate Limit and save the parameters to a file (on the File menu, click Save). Whenever you start RMCWin, read the parameters from the file and the problem should be corrected.
