Using the Communication Options Tab
The Communication tab of the Options dialog box is used to select and configure a communication path to an RMC.
To use the Communication tab:
  1. Start RMCWin.
  2. On the Tools menu, click Options, and then click the Communication tab.
    You can also double-click the Communication pane of the main window's status bar, or right-click this pane and then click Communication Options from the shortcut menu. The Communication pane is the one that displays the communication path and state (e.g. "COM1: Offline").
  1. Select the appropriate driver and options.
  2. Click OK.
Note: Many options available in the Communication tab of the Options dialog box can be changed more quickly using the shortcut menu on the Communication pane of the status bar. To open this shortcut menu, right-click on the Communication pane of the status bar (e.g. "COM1: Offline").
RMCWin can use one of three drivers for communicating between the PC and RMC. Each is described below:
Note: If your computer has a firewall, it may prevent RMCWin from finding RMC100s on your Ethernet network from the Communications tab in the Options dialog. See the Setting the Firewall to Allow RMC100 Ethernet Browsing topic for details.
In addition to the driver selection and driver-specific options, there is one other option offered by this dialog box:
