Quadrature Configuration
The RMC supports a wide range of quadrature encoders and homing configurations. To select the type of the quadrature encoder and the polarity of the drive output, the following settings can be changed:
No jumpers are required for changing any of these settings. You need to set the Configuration word parameter for each axis used.
Defining the Encoder Error/Fault Input Status Bit
This status bit can represent either an encoder error or a fault error. The user configures which of these two conditions is reported in this status bit. There are four options:
The use of this bit can be set only from RMCWin. Use the following steps:
  1. On the Tools menu, click Module Configuration.
  2. In the Slots list, click the Quadrature module you want to edit.
  3. Click Slot options. The Quadrature with Analog Output Options dialog box will be displayed with a tab for each axis on that slot.
  4. Click the Axis 0 tab.
  5. Check the conditions that you want to have set this status bit. You can check one, both, or neither condition.
  6. Click the Axis 1 tab.
  7. Check the conditions that you want to have set this status bit. You can check one, both, or neither condition.
  8. Click Update RMC.
  9. The Update Module Configuration dialog box will be displayed to indicate the progress. If the module could not be reset automatically, you may be prompted to reset the module yourself.
See also:
Quadrature Overview
Quadrature Wiring
Quadrature LED Indicators
Quadrature Specifications
Quadrature Scaling
Quadrature Homing
