FINS/UDP
The FINS/UDP protocol is an Omron protocol which can be used by a PLC program to transfer data and perform other services with a remote PLC connected on an Ethernet Network. The FINS protocol allows Omron PLCs to communicate with the RMC75E, RMC150E, and RMC200. The RMCs support FINS/UDP.
The FINS/UDP protocol is an open application protocol developed and used by Omron Electronics Inc. This protocol is available over a number of media, including Ethernet and serial. Additional information is available in the CS1 Communications Reference Manual, available on Omron's web site: https://www.omron.com/oei.
The FINS protocol uses a three-stage addressing system: network address, node number, and unit number. These three address elements have the following purposes:
The RMC does not require manually setting these values in the RMC. Only the IP address needs to be set in the RMC; see the RMC Ethernet Setup topic for details.
Addressing:
See the FINS Addressing topic for information on the FINS address of RMC registers.
RMC Ethernet Protocols | Ethernet Overview | Using Omron PLCs with the RMC | FINS Addressing
