RMCLink.Interop .NET Assembly RMCLink.LRegToFReg Method |
Converts an L register value into an intermediate form used when writing mixed F and L registers with WriteFFile.
Shared Public Function LRegToFReg ( _ registerValue As Integer, _ ) As Single |
Dim registerValue As Integer Dim returnValue As Single
returnValue = RMCLink.LRegToFReg(registerValue) |
static public float LRegToFReg ( int registerValue ) |
public: static float LRegToFReg ( int registerValue ) |
registerValue
The value of the L register.
The same regValue L register value, but as a System.Single data type ready to write with WriteFFile. Notice that this value is not usable at this stage. That is, it will appear to be a garbage value.
This function is used when writing to L registers in an RMC70, RMC150, or RMC200 using the WriteFFile method. Notice that this should only be done when the write is writing a mixture of L and F registers. Otherwise the WriteLFile method should be used to write exclusively F registers. Refer to the RMC70, RMC150 and RMC200 Register Data Types topic for details on L and F register types and on how to mix the two in a single read or write.
No exceptions are generated by this method.
The following code example illustrates the use of the LRegToFReg method.
' Assume that the first two variables are defined as follows:
' L56:0 - LoopCount (DINT, L register)
' F56:1 - SetPoint (REAL, F register)
' We want to write to both is a single write, but because they
' are mixed L and F registers, we must use the special LRegToFReg
' function to place the L register values in the array.
Dim data() As Single = New Single(1) {}
data(0) = RMCLink.LRegToFReg(4) ' LoopCount will be 4.
data(1) = 10.5 ' SetPoint will be 10.5.
' Write to these two registers.
rmc.WriteFFile(FileNumber70.fn70VarCurValues, 0, data, 0, 2);
// Create the object itself.
// Assume that the first two variables are defined as follows:
// L56:0 - LoopCount (DINT, L register)
// F56:1 - SetPoint (REAL, F register)
// We want to write to both is a single write, but because they
// are mixed L and F registers, we must use the special LRegToFReg
// function to place the L register values in the array.
float[] data = new float[2];
data[0] = RMCLink.LRegToFReg(4); // LoopCount will be 4.
data[1] = 10.5; // SetPoint will be 10.5.
// Write to these two registers.
array<float>^ data = gcnew array<float>(2);
data[0] = RMCLink::LRegToFReg(4); // LoopCount will be 4.
rmc->WriteFFile(FileNumber70::fn70VarCurValues, 0, data, 0, 2);
