RMCLink.Interop .NET Assembly RMCLink.Dispose Method |
Releases the unmanaged resources used by the RMCLink object. This includes the internal RMCLink COM component and any in-use TCP/IP connections or serial ports.
Public Sub Dispose |
Dim instance As RMCLink
instance.Dispose() |
public void Dispose () |
public: void Dispose () |
Calling Dispose allows the resources managed by the RMCLink object to be released. This will release the reference to the RMCLink COM component and if the link was connected, Disconnect will be called internally.
This function is not typically needed in applications, unless you want to force the release of the RMCLink COM component. However, the user typically does not care when the RMCLink COM component itself is released. The only release issue that the user cares about is when the serial port or TCP/IP connection is released, and this can be done by the Disconnect method. Calling Disconnect from inside the finally branch of a try-finally block can ensure that these resources are freed up even when exceptions are thrown.
No exceptions are generated by this method.
