RMCLink C++ Wrapper Class CRMCLink::LRegToFReg Method |
Converts an L register value into an intermediate form used when writing mixed F and L registers with WriteFFile.
static float LRegToFReg( long regValue ); |
regValue
The value of the L register.
The same regValue L register value, but as a float data type ready to write with WriteFFile. Notice that this value is not usable at this stage. That is, it will appear to be a garbage value.
This function is used when writing to L registers in an RMC70, RMC150, or RMC200 using the WriteFFile method. Notice that this should only be done when the write is writing a mixture of L and F registers. Otherwise the WriteLFile method should be used to write exclusively F registers. Refer to the RMC70, RMC150 and RMC200 Register Data Types topic for details on L and F register types and on how to mix the two in a single read or write.
The following code example illustrates the use of the LRegToFReg method.
// Assume that the first two variables are defined as follows:
// L56:0 - LoopCount (DINT, L register)
// F56:1 - SetPoint (REAL, F register)
// We want to write to both is a single write, but because they
// are mixed L and F registers, we must use the special LRegToFReg
// function to place the L register values in the array.
float afData[2];
afData[0] = CRMCLink::LRegToFReg(4); // LoopCount will be 4.
afData[1] = 10.5; // SetPoint will be 10.5.
// Write to these two registers.
pRMC->WriteFFile(CRMCLink::fn70VarCurValues, 0, 2, afData);
