RMCLink C++ Wrapper Class CRMCLink::WriteLFile Method |
Writes to one or more integer (L) registers in the controller. Since all RMC100 registers are integer registers, this function should be used for all writes to RMC100 controllers. WriteLFile should also be used when writing integer values to RMC70, RMC150, or RMC200 registers. Compare with WriteFFile.
HRESULT WriteLFile( UINT file, UINT element, UINT count, long const* pData ); |
File number of the first register to write to. See the RMCLink Register Reference for details.
Element number of the first register to write to. See the RMCLink Register Reference for details.
count
The number of registers to write.
data
Points to the data to write to the controller, which must be a long array of at least count elements.
E_OUTOFMEMORY |
E_INVALIDARG |
One of the file, element, or count parameters are out of range. |
RMCLINK_E_DISCONNECTING |
RMCLINK_E_DISCONNECTED |
RMCLINK_E_SOCK_INTERNAL |
RMCLINK_E_CANCELLED |
RMCLINK_E_TIMEOUT |
RMCLINK_E_SOCK_ERROR_RD |
RMCLINK_E_SOCK_INV_RD_LEN |
RMCLINK_E_SOCK_ERROR_WR |
RMCLINK_E_SOCK_INV_WR_LEN |
RMCLINK_E_CE_IOE |
Serial IOE error. |
RMCLINK_E_CE_FRAME |
Serial framing error. |
RMCLINK_E_CE_BREAK |
Serial Break error. |
RMCLINK_E_CE_OVERRUN |
Serial overrun. |
RMCLINK_E_CE_RXOVER |
Serial receive overrun. |
RMCLINK_E_CE_RXPARITY |
Serial parity error. |
RMCLINK_E_CE_TXFULL |
Serial transmitter full. |
RMCLINK_E_CONN_BROKEN |
RMCLINK_E_PARTIAL_WRITE |
RMCLINK_E_READ_ONLY |
Attempt to write to read-only registers. |
RMCLINK_E_BAD_ADDRESS |
Attempt to write beyond the end of a file. |
RMCLINK_E_USB_SETTIMEOUT |
RMCLINK_E_USB_OP_ABORT |
RMCLINK_E_USB_DISCONNECT |
The following code example illustrates the use of the WriteLFile method.
CRMCLink* pRMC = CRMCLink::CreateEthernetLink(CRMCLink::dtRMC100, _T("192.168.0.28"));
// Issue a Go (G) command to Axis 0 (registers L8:0-5).
long alCmd[6];
alCmd[0] = 0x0081; // Mode (S-Curves, Accel/Decel Mode 1)
alCmd[1] = 100; // Acceleration Rate (100 in/s/s)
alCmd[2] = 100; // Deceleration Rate (100 in/s/s)
alCmd[3] = 10000; // Requested Speed (10 in/s)
alCmd[4] = 4000; // Requested Position (4 in)
alCmd[5] = 'G'; // Go (G) command
hr = pRMC->WriteLFile(CRMCLink::fn100CommandAxis0, 0,
CRMCLink::rmc100CmdRegsPerAxis, alCmd);
printf("Command successfully written.");
CRMCLink Class | RMCLink C++ Wrapper Class | WriteFFile
