RMCLink C++ Wrapper Class CRMCLink::WriteFFile Method |
Writes to one or more floating-point (F) registers in the controller. Notice that since all RMC100 registers are integers, WriteLFile should be used instead for that controller type. Use WriteFFile when writing to floating-point RMC70, RMC150, or RMC200 registers. Compare with WriteLFile.
HRESULT WriteFFile( UINT file, UINT element, UINT count, float const* pData ); |
File number of the first register to write to. See the RMCLink Register Reference for details.
Element number of the first register to write to. See the RMCLink Register Reference for details.
count
The number of registers to write.
data
Points to the data to write to the controller, which must be a float array of at least count elements.
Notice that all RMC100 registers are integers. Therefore, using this method to write data to the RMC100 will simply round the values to integers before writing them to the controller.
E_OUTOFMEMORY |
E_INVALIDARG |
One of the file, element, or count parameters are out of range. |
RMCLINK_E_DISCONNECTING |
RMCLINK_E_DISCONNECTED |
RMCLINK_E_SOCK_INTERNAL |
RMCLINK_E_CANCELLED |
RMCLINK_E_TIMEOUT |
RMCLINK_E_SOCK_ERROR_RD |
RMCLINK_E_SOCK_INV_RD_LEN |
RMCLINK_E_SOCK_ERROR_WR |
RMCLINK_E_SOCK_INV_WR_LEN |
RMCLINK_E_CE_IOE |
Serial IOE error. |
RMCLINK_E_CE_FRAME |
Serial framing error. |
RMCLINK_E_CE_BREAK |
Serial Break error. |
RMCLINK_E_CE_OVERRUN |
Serial overrun. |
RMCLINK_E_CE_RXOVER |
Serial receive overrun. |
RMCLINK_E_CE_RXPARITY |
Serial parity error. |
RMCLINK_E_CE_TXFULL |
Serial transmitter full. |
RMCLINK_E_CONN_BROKEN |
RMCLINK_E_PARTIAL_WRITE |
RMCLINK_E_READ_ONLY |
Attempt to write to read-only registers. |
RMCLINK_E_BAD_ADDRESS |
Attempt to write beyond the end of a file. |
RMCLINK_E_USB_SETTIMEOUT |
RMCLINK_E_USB_OP_ABORT |
RMCLINK_E_USB_DISCONNECT |
The following code example illustrates the use of the WriteFFile method.
// Issue a Move Absolute command to Axis 0 (registers F16:0-5).
float afCmd[6];
afCmd[0] = 20; // Move Absolute (20)
afCmd[1] = 10.5; // Requested Position (10.5 in)
afCmd[2] = 12.5; // Requested Speed (12.5 in/s)
afCmd[3] = 100; // Acceleration Rate (100 in/s/s)
afCmd[4] = 100; // Deceleration Rate (100 in/s/s)
afCmd[5] = 0; // Direction (0=nearest)
hr = pRMC->WriteFFile(CRMCLink::fn70CommandArea, 0,
CRMCLink::rmc70CmdRegsPerAxis, afCmd);
printf("Command successfully written.");
CRMCLink Class | RMCLink C++ Wrapper Class | WriteLFile
