Parameter Area
This area is located in the lower right portion of the main window. It holds the Parameter fields for each axis. This area is updated only in Read-back Mode. Refer to the following sections for details on the parameter fields:
Configuration Word
Scale
Offset
Extend Limit
Retract Limit
Proportional Gain
Integral Gain
Differential Gain
Extend Feed Forward
Retract Feed Forward
Extend Acceleration Feed Forward
Retract Acceleration Feed Forward
Dead Band Eliminator
In Position
Following Error
Auto Stop
To the right of each of the Parameter field labels are the values for the parameter fields for each axis. You can change these values using the keyboard as described in Changing Data from the Keyboard. Changes are sent to the RMC only when a Set Parameters Command is issued. There are several ways to send this command:
Note: The color of the Parameter values is significant. If all parameters for an axis are displayed in WHITE, then no parameters have been changed since the last time they were sent to the RMC, otherwise they are displayed in RED. This is done to remind the user to send a Set Parameters Command after updating a parameter. After this command is issued to an axis, the parameters for that axis will be displayed in WHITE.
Note: When in Read-back Mode, you will notice that RED parameters will be replaced with WHITE parameters as the current values are read from the RMC. This is done to indicate that the values displayed match those used by the RMC.
For details on saving and loading parameters, see Changing Between Board Files.
